DOE
05-02-2022, 09:42 PM
When I try to fax I can hear a dial tone and hear it call the other fax and it rings and squeals but never scans documents. I don’t get any error codes. They say print will work one day and then not the next. After they send the job to the machine the machine will fire up like it’s going to print and then say canceled in the window on the copier. Customer thinks copiers possessed the way it works one time and not the next. When I went today you couldn’t even copy it said the memory was full I turn the main switch off and on and that went away and I was able to copy. Any ideas
