View Full Version : Increased (M)Toner Consumption C3320i
Tiagocang
05-02-2022, 11:28 PM
Today had 2 C3320i with same problem, over consume Magenta toner both with 10k counter +-.... is the G00-B5 still a good fix for this?
I think G00-M2 is the latest FW - you'll find some more infos obout this problem in other threads. I think it was about the C3350i/c4050i but they share the same engine. Short version: There's some sort of "high speed dev mix mode" added in newer firmware you can perform to remove clogged dev/toner from the TD sensor. I think you have to check some voltages before/after the procedure and if they don't improve the IU might be bad.
Woxner
05-03-2022, 09:21 PM
one of the big problems is the gradation is not being done at set up. so the voltages are screwed up. they all read 0. after you get the ratio's where they need to be do the gradation. i have not had a problem since i do this step. in some cases you may need to start with new image unit. i have seen yellow do this as well.
Tech Helpdesk
01-18-2023, 03:53 PM
It's been a while since the high speed agitation firmware came out and dare I ask if anyone has noticed any improvements with IU reliability ?
Just asking as we seem to be going through a few imaging units again.
tsbservice
01-18-2023, 07:26 PM
I think they did some modifications on developer unit mixing shafts to agitate mixture better around TCR sensor... but maybe I'm dreaming :cool:
Markks
01-19-2023, 12:47 AM
Latest firmware is G00-N4. see attached for toner depletion problem5638656385
Markks
01-19-2023, 12:49 AM
not sure why other two files didnt attach. trying again5638756388
B0265
01-19-2023, 07:29 AM
A comment on the bulletin 12202:
To run the high-speed agitation, select “Initialize+Image Stabilization" (The process will run for about 4 minutes)
kingarthur
01-19-2023, 12:34 PM
You forgot to add - all the paper trays have to be open
Tech Helpdesk
01-19-2023, 04:28 PM
We have loaded the firmware since its launch and done the high speed agitation, however the problem seems to come back especially if the machine is sat idle for a while.
Previously we had similar experiences with the C1070 print production machines when they were switched off over Xmas.
I am aware of the developer unit modification and I have been informed that these wont appear in the UK until Feb at the earliest.
Markks
01-20-2023, 01:47 AM
Have you pulled hv board and scraped the contacts for the bias connectors ?
Tech Helpdesk
01-23-2023, 02:06 PM
Hi Markks, we have checked and cleaned all hv connections as well as imaging unit plus toner chip connectors, shaken the imaging units and toners but they still fail prematurely.
Our impression of the machine is it isn't fit for purpose
