ltdiniz
05-25-2022, 09:55 PM
Hi,
I have a Bizhub C224e.
I would like to know if there is a general clear type MFPB and PRCB boot firmware other than A145fw.tar.
That this clear type method that leaves the eqto as if it were in the initial factory production line that can release the CE password if it is blocked and TCR sensor adjustment type adjustments (example).
I believe it would be a Custom Firmware developed by an engineer here on the Forum.
I have the following situation!
Error C2557-2558-2553 and all C,M,Y,K Full Develop Drives have already been replaced.
And yet the TCR stays at 0.01 black and automatically switches to TCR 0.00 Magenta.
Made the exchange PWB Assembly (FRB) for another working normal and tested ok.
Done Reset Tools and recovery data via (A145fw.tar)
Memory Clear and Format HD
Swap SSD and MFPB
And even so, the Equipment works a little and presents error C2557-2558-2553 and generates an error of some TCR goes to 0.00 or Black or Magenta
If any engineer has this custom FW and can help me and send me a PM I would really appreciate it.
Thank you for now.
Swap SSD and MFPB
Thank you for now.
