View Full Version : 270GSM wont feed through bypass C300i
rrrohan
05-30-2022, 09:17 AM
Have not been able to get any C300i to feed customers 270GSM card stock through bypass tray but its ok from tray 1.
The pickup roller doesnt slip on paper it just doesnt spin. Works fine on other stock though and copier is brand new.
if i totally remove sep roller but leave the guide install it feeds fine but would limit them to only a single page in tray at a time.
I tried cutting a loop or so out of sprint to allow it a larger gap but didnt help.
any idea?
or should i just try taking more off the spring? I really thought the new pickup assy would of worked much better than previous generations but surprisingly this card stock went through the old 8 series fine
You have see this ?
The paper JAM may occur from the bypass tray (PSKM_BT2013209EN) 53450
rrrohan
05-30-2022, 11:10 AM
thanks ill try this part
+ use the previous generation sep roller
blackcat4866
05-30-2022, 02:42 PM
... The pickup roller doesn't slip on paper it just doesn't spin...
You can stop right there. Focus on the pickup roller drive, clutch or one-way. A simple test is to reach into the slot with your finger and roll the pickup tire one-direction, then the other to see if that one-way is slipping. =^..^=
suomi
05-31-2022, 06:19 AM
The new bypass is simply worse than the old version on thick paper.
Yeah we had to modify some because the thick paper wont't pass the sep roller. Our first attempt was using a corrugated rubber roller for pickup and fiddling around with the sep roller assy - that worked "okay-ish". Final solution was just a downgrade to the old style sep roller.
rrrohan
02-03-2023, 04:54 AM
I just tried this on another customers copier having same issue as my previous customer and now its working like a charm.
i noticed the i series sep roller is clutchless compared to the one way spring on the 8 series. might start doing this to all i series at runup
KMFLT3CH
02-03-2023, 02:22 PM
Just to verify, you are referring to part # 4658015106 for the old sep roller?
56670
rrrohan
02-03-2023, 11:34 PM
56670
Well thats the one i am now using and its so far so good
Markks
02-04-2023, 12:20 AM
Just wanted to add, that Compression Spring AA7NP10100 is available for the i series. It is a different separation pressure spring which is for machines that have issues with envelopes and thick paper from the bypass tray...
blackcat4866
02-04-2023, 02:33 AM
Thanks Markks! =^..^=
rrrohan
02-05-2023, 01:33 AM
good to know. im happy enough just installing 8 series sep roller but i guess changing spring is slightly quicker
femaster
02-06-2023, 05:08 AM
Probably a lot cheaper too, unless you happen to have excess stock in the separation rollers.
Yeh sorry for the late reply due to holiday, I'm glad it helped!
