View Full Version : Miscellaneous Install firmware does not work | C3351
hobbele
05-30-2022, 12:35 PM
Hello, everyone,
I have problems with a bizhub C3351... I can no longer install the firmware.
The machine was flattened with Clear All Data and the Reset Tool because it kept producing strange data before and blocked the print queue.
If I now try to flash the firmware, the MFP board runs at 100%, scanner/printer stops at 10% and then displays NG.
But I can start up the machine and print normally...
https://i.ibb.co/KhxQzxk/Firmware-c3351.jpg (https://ibb.co/zxVLHVY)
What confuses me is that everything still works - as far as I've tested - when I boot up the machine...
tsbservice
05-30-2022, 06:39 PM
Check printer and scanner serial numbers and also machine type. As per another experienced member here(Synthohol). Try to do only troubled part of firmware.
hobbele
05-30-2022, 06:56 PM
Thank you, I'll check that out tomorrow. The machine type should match.
It's a C3351 and the type is A 2
So you mean I should only activate printer/scanner? Disable MFP?
tsbservice
05-30-2022, 07:10 PM
Yes try to do only printer/scanner firmware.
Synthohol
05-30-2022, 09:48 PM
on the old 223 series the scanner FW used to fail all the time. they released scanner only FW later but yes, try just scanner and turn off everything else.
also make sure the scanner serial# is listed, that the machine and type are correct as well.
Won't hurt to prepare another stick from scratch and/or cross-check yours with another C3x51.
hobbele
06-01-2022, 11:56 AM
Hello and thank you for your many tips.
Unfortunately I still have the same problem.
The serial number was entered but wrong, I have now corrected it
Firmware update without MFP board.
Machine Type is corecct - A 2
I also tried different USB sticks. also different old firmwares
https://i.ibb.co/4PGkwdH/IMG-8099.jpg (https://ibb.co/FgMpkVF)
Does anyone else have an idea?
Nothing besides heavy "trial and error" - like flashing/downgrading a really ancient firmware or reset the machine via SP / memory clear.
I'd probably just leave it (if it works) ;)
mojorolla
06-01-2022, 02:46 PM
Prep your jump drives using this procedure:
5348153481
hobbele
06-02-2022, 01:34 PM
Prep your jump drives using this procedure: :)
Hey thanks
my jump drives couldn't be formatted, so I did everything it said. It worked, but the firmware just won't install...
I'd probably just leave it (if it works) http://www.copytechnet.com/forums/images/smilies/wink.png
If no one has any more tips, I'll just leave it as it is and configure and test the machine as far as it goes. Hope everything works then.
