Bizhub c454e gradians problem
  • mramlawi
    • Jul 2011
    • 838
    Dears ,
    its a weird problem, on this machine it make a gradians color start normal from the and start to get lighter on the other side using a4 plain paper also think a4/a3.
    by the way the cmyk test is perfect
    changed itb,drums,developer,transfer roller on right door stop it before the heater and still the same .
    any suggestions please
    thanks
    Distinguished road makes you jewel in rough
  • mramlawi
    • Jul 2011
    • 838
    Re: Bizhub c454e gradians problem
    Originally posted by mramlawi
    Dears ,
    thanks
    as i uploaded the photos to check how it start in a good density from side and how it comes lights on another side
    • Toxic
      • 694
      Dirty poligon motor...?
      Check this topic
      C224e Print Quality Issues (Problem & Solution)
      • tsbservice
        Field tech
        • 7923
        If it's not dirty poly motor mirrors try to push side door while making test print and see if quality change. You may have something bent or door is not latching enough.
        • mramlawi
          • Jul 2011
          • 838
          Check this topic
          I already clean the laser and still the same
          • Hansoon
            • Sep 2007
            • 3350
            Did you clean not only the slit glass of each color, but also the polygon mirror and others inside the, more or less sealed, box?
            Hans
            “ Sent from my Intel 80286 using MS-DOS 2.0
            https://www.copytechnet.com/images/smilies/biggrin.png
            • mramlawi
              • Jul 2011
              • 838
              Hans
              yes sure i remove all the laser and clean the polygon motor nothing change
              • mramlawi
                • Jul 2011
                • 838
                Already pushed the door and nothing change that made me really crazy
