emujo2
06-17-2022, 06:50 PM
We have had 1000s of these "cant scan to email" calls..I wanted to offer some help if needed..
In an nutshell Gmail has decided that basic authentication is not secure enough and wants all (non enterprise) users to enable 2FA and generate an App Password..The new APP password is usually the only think in the copier that needs to be changed. However , older devices that have been sitting there, fat dumb and happy for the last 10 years are also failing..What I have found is that in many of these older machines (423, 203, C452 ect)..The moment you go into admin mode the SSL cert shows weak and the connection fails, so you can't make the changes needed..DO NOT Start out with a HDD format..instead (and I've only tested this with Firefox), open a new browser window..type about:config...This will open a search window, type TLS and change the minimum TLS level from 4 to 1, this drops the TLS level requirement and will allow you to get into pagescope admin mode. Depending on the model, a firmware update might add TLS 1.2 but that's up to you to research and update. Once you have changed the APP password, logout and change the browser config TLS setting back to 4 (1.2 minimum level). If anyone wants to add the Edge and Chrome config process please do so..I tried the edge recommendation, but could not find any TLS entries. Edit...And BTW, the customer should be paying for this service (IMHO) if they refused to add any network support to their contract, but that is an argument for another thread..E
