View Full Version : konica minolta c458 problem jam paper
enricocopyline
06-22-2022, 04:39 PM
i have a problem with a konica minolta c458. the copier jams paper 12-01 and 11-01 both from the first and from the second drawer I tried to change the paper outlet but I have not solved the problem it works fine from the 3rd drawer. it seems as if the rubber tires are not turning.
what could I do?
thanks
tsbservice
06-22-2022, 06:03 PM
bizhub C458 from Tray 2 Jam-code 12-01 (feed roller didnīt rotate) (https://www.copytechnet.com/forums/konica-minolta/138223-bizhub-c458-tray-2-jam-code-12-01-feed-roller-didn-t-rotate.html)
Check one-way and shaft.
enricocopyline
06-22-2022, 08:29 PM
I had read, however, the gears turn. it seems that there is no current when you have to close the clutch that turns the rubber pads
copier addict
06-22-2022, 08:57 PM
what could I do?
thanks
Where is the paper stopping? Is it making it out of the tray? Does it stop at the same place from both trays?
enricocopyline
06-22-2022, 09:54 PM
paper does not feed from the drawer in both trays
copier addict
06-23-2022, 12:10 AM
Remove tray 1, load paper in tray 2, and watch through the tray 1 gap to see if anything is moving when you try to print from tray 2
enricocopyline
06-23-2022, 10:40 AM
I did it but nothing moves
do you have any firmware that you can send me to try an update?
and if possible also the animated guide
konica.copyline@gmail.com
thanks
Synthohol
06-23-2022, 01:29 PM
^^^^most likely cause^^^^^
blazebusiness
06-23-2022, 02:26 PM
+1 , it's the one way or the Konica Minolta bizhub C458 Paper Feed Drive Assembly A79JR70222
enricocopyline
06-23-2022, 08:37 PM
after all the tests I suspect that a good technician has mounted the entire pickup roller of another machine in the machine.
the attack is the same but in my opinion the tensions that start the clutches do not return
Synthohol
06-23-2022, 08:49 PM
the one way clutch bearings are not included when replacing the rollers and is easily overlooked.
