Minolti DI 450 / PI5501
  • leroy
    • May 2025
    Have a new customer that wants to hook up his DI450 to use as a printer and scanner, with a PI5501.
    Will the PI5501 run on Windows XP or is he limited to something older?
  • buster68
    • Nov 2008
    • 181
    yes...it will work with windows xp. Set up the printer port as LPR and the queue name is PORT1
    • leroy
      Thanks much for the answer.
      • leroy
        One other question. Can that be set up wireless, through their router, or does it have to be hard wired?
        • DallasTech
          • Feb 2007
          • 119
          hard wired, unless you use a wireless bridge. You can use the above ^^ LPR port or raw port 10001.
          scanning on those machines suck, so good luck with scanning. I have told our customers we now longer support scanning on that model, because it's so old.
