View Full Version : Fiery Reload.... IC-409
methogod
07-28-2022, 05:26 PM
I know this is old, but i want to sell it as working...
have both the 1.1v system and user iso from MKM.
have the latest FIERY USB SETUP TOOL 2.0.26
Tried 2 PCs and wont load the attached files...
do i need to use an older version of the FIERY USB SETUP TOOL?
EFI said tool old they dont have files...
going to try to load 1.0 and see if any different
54140.
Synthohol
07-28-2022, 10:12 PM
i never use the USB method, use this instead.
worked for me couple hundreds times over the years ;)
does not have to be a crossover cable, straight ones work too as most PC nic cards will auto adjust.
just set the PC to dhcp and the software will find it.
methogod
07-29-2022, 05:18 AM
didnt find it... get an error "BOOTPD : Socket has not been created 9XXXX"
so weird, i added a DVD rom drive, boots a windows disk and linux USB boot disk, but every ISO i burn it wont boot. just hangs.
Does it want a CD and not a DVD?
going to make a real crossover...
do you have to manually set your IP? 192.168.1.100 255.255.255.0
Synthohol
07-29-2022, 12:33 PM
dhcp on PC, and i use powerISO to make a virtual DVD and run the install from it. no need to make a real disk :)
methogod
07-29-2022, 07:59 PM
on a windows 10 PC? or older?
making a cross over cable this weekend. Then ill know.
just like to ship it working.
Synthohol
07-29-2022, 10:29 PM
remember, flip the switch(s) shown in the guide i posted and hook the laptop to the copier port on the fiery, not the lan one.
copyman
07-29-2022, 11:20 PM
I'm sure Synthohol 's advice is way to go.
Back when I had those old Fiery's on BizHub C253 & C451's I only used Win XP to re-write the system software. Used a crossover cable if i remember correctly. Only had a few machines with Fiery's (Thank God)
methogod
08-01-2022, 06:47 AM
That worked, had to install XP on a old laptop and use a crossover cable. Fiery's working v1.1
But the C451 is not... has intermittent power off when waking from sleep. Like power supply is failing. Maybe a swollen cap or 3. Worse when FIERY plugged in, less when plugged into separate outlet.
Should i just replace the power supply?
Synthohol
08-01-2022, 01:33 PM
personally i would just disable sleep mode entirely.
happy to hear the Fiery restore worked.
wjurls
08-02-2022, 11:27 PM
I have found the you can have the ISO file on a USB and right click it and select "mount" in Windows 10 it will behave just like a cd/dvd.
methogod
08-03-2022, 06:39 AM
Couldn't get the Fiery USB builder to recognize either version ISO (1.0 and 1.1)
only way I got it to work with with a windowsXP install on a old laptop and a crossover cable.
Took 15 minutes...
I reloaded a IC417 with the same Fiery USB builder and it worked fine.
who knows... old stuff always weird.
Walterj
08-04-2022, 11:01 AM
54140.
Hello
Good day
In this IC 409 you can also load the System Software with USB, but remember that the System Software version 1.0 is not compatible with the Bizhub 253/353
here is the download link for the application https://we.tl/t-B5q8qzrjQA (https://we.tl/t-B5q8qzrjQA), it will only be available for a week
Luck
