View Full Version : Miscellaneous Bizhub c2070
chughtai
08-02-2022, 06:47 PM
hi every one for konicaminolta expert engineers
i have bizhub c2070 copier i facing error for gamma adjistment C2811 and C2814 yellow and black developer and developer units and
registration sansor. sum time yellow and sum time black gamma problem. i replace all parts according to manual but problem are still same.
if any one face like this problem help.
thanks.
allan
08-02-2022, 07:05 PM
thanks.
Could be drums and or charge units if they are over life.
Check the DPS input values under input check. If it stuck at 0 or 255 then its probably an electronic or wiring issue. If its just too low or less likely high then it could be a charge relate component.
chughtai
08-02-2022, 07:55 PM
allan dear
what is the DPS input values
and where can i found
allan
08-02-2022, 08:48 PM
O dear...
Do you have a manual?
chughtai
08-03-2022, 07:00 AM
yes i have manual
chughtai
08-03-2022, 07:18 AM
sorry to say what is the full definition for DPS input value.
