Olivetti D-color MF652 black dev installation error
Re: Olivetti D-color MF652 black dev installation error
Originally posted by Luis
Yes my friend I did reconnect the wires.
Have you made sure to use the correct chip? You can't use a color chip on the K Dev.
Do a System Error Clear in Service Mode if you are sure that you used the correct chip and error should be gone.
Also make sure that you use original chips and not some atermarket bullsht
Did any developer dump into the cavity? If the IU does not seat properly this can happen. If the drum is not hooked in properly the contacts can bend. Press on the unit while making the door switch see if that clear the message.
