View Full Version : Scanning of 130F
kiwitechnician
01-20-2009, 07:16 AM
Hi guys, can anybody help with scanning on this machine. I am not sure about that how to do.
I instalated the GDI driver which should be together with scanner driver but I still get the message: Can't connect to 130F scanner
If I want to install the scanner the Xp can't see him but I am sure it is there.
ni311
01-21-2009, 05:43 PM
Is the driver listed in Device Manager / Imaging devices?
From my knowledge, once you installed the printer driver, the scanner came with it automatically.
kiwitechnician
01-24-2009, 07:23 PM
I thought the same but I couldnt see it in device manager. When I tried to connect the scanner I got the message ,,failed to connect the scanner,,
The local connection was fine I could print the test page.
harry2007
01-24-2009, 08:23 PM
-uninstall previous driver (130f)
-delete konicaminolta 130f folder on C.
-restart pc
-do not connect copier to pc at this time
-insert original CD an follow the wizard to the end
-insert USB cable
-when ask about path -browse to konicaminolta 130 f folder on C.
-for scanning use a spec program (adobe, corel, irfanview, acdsee,..)
enjoy !
kiwitechnician
01-25-2009, 08:50 AM
I thoght the same but I was wondering your opinions and experiences with this machine. The less machine the bigger issues,bloody machine.
I will try it on Monday, let you know what happens.
