This error showed up 4 times in the trouble counter. Does anyone know how to fix it? Could be related to this issue - fuzzy black and cyan printing, that I had with the same machine? Help!
bizhub C350 problem C13D5 LPH download
l can healpe you friend ...
hi friend printech ..l have manual of this copier if this manual healpe you ...tell me your mail ...BEST TECHNICIAN . NICE PEOPLE . -
Code means an error was detected whlile downloading LPH correction data from the eeprom of the LPH to the PWB-MFP when the power switch is turned on. Your code is for the cyan. Check your connections in the wiring harness. If you have to chane parts, you would have to start with the print head, then the cyan LED, then the PWB-MFp, ect. ect.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
I went back to the machine today and the error is actually like this: "C13D5/6/7/8 LPH download" - 4 . My e-mail is zdrangbang@yahoo.com (yes, Zaza, I need the manual, Thanks!).
Does this mean that all the printheads are bad?Comment
That is the list for all 4. The odds of all of them going bad at the same time would not good. I would look to reflash the firmware first and then swap out the LPH with one you know is good. Sometimes just replugging in the harness connections can do the trick. Good luck.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
Thank you, fixthecopier, I think you're right, I should try to do the firmware first. Do you or anyone else has the 3.0 for the standard controller? All I have is 2.5 version. Thanks in advance for firmware (my email is zdrangbang@yahoo.com)!Comment
