View Full Version : DV-610 in C1060 series.
wjurls
08-19-2022, 06:15 PM
Has anyone tried using DV-610 Developer from the C7000 series in the C1060 series machines? Or even DV-613 for the C8000? Charging by weight of course.
I'm curious if it's the same or very similar formula. DV-614 prices have nearly doubled lately and it's killing me.
otphas
08-27-2022, 04:24 PM
Hi ,
C6000/7000/8000/1085/1100 are same , C 1060 series not !
blackcat4866
09-01-2022, 03:13 PM
I substituted DV-610 instead of DV-614 in a C1060 today. The quantity is different and I wasn't exactly prepared for that, so I estimated the quantity of developer. It stirred without error and made good quality images. The shade of cyan is slightly different, but will self-correct as the TN-619C toner is drawn from the hopper. The big question for me is what will the quality look like in a month? =^..^=
otphas
09-01-2022, 08:00 PM
Post here after a month what is the result.
Alexsky
09-01-2022, 11:45 PM
Hi ,
C6000/7000/8000/1085/1100 are same, Itīs NOT the same, itīs similar, look composition for each,
blackcat4866
09-02-2022, 02:21 PM
Ok Alexsky, I accept that it's not the same.
Let's see how it works. This enduser runs 60% to 70% monochrome, so it wasn't going to make yield anyway. =^..^=
wjurls
09-06-2022, 11:24 PM
Interested to see how this works out over time. I have a very accurate refrigerant charging scale I could use to get the weight right. IMHO the C1060 series of machines used developing units that are way too small to keep up in high a productivity, high coverage environment. Constant issues with developer in them and the cost is way too high.
blackcat4866
09-06-2022, 11:36 PM
The biggest problem I've noticed is when the enduser does a lot of low density monochrome prints. The color developers tend to over-tone. Ideally, if the enduser did 100 full color images in-between 1500 black only images it would maintain density fine. Unfortunately my enduser does 100K black images consecutive, then wonders what happened to the color developers. I've taken measures to increase the frequency of the color patches, which does seem to help ... but it's not a solution.
The real solution is to have a monochrome only machine to run those monochrome images, but I don't expect that to happen.
L0rdC
09-09-2022, 08:25 AM
We have a client similar to the one you mention, it prints 5 sheets per month in color and the rest in monochrome, finally I have chosen to deactivate the color in the adjustment process because the color in this client is not profitable.
And speaking of the DV subject, I have used the dv-610 in all the models that we have in maintenance and I have never had any problem with duration or quality.
blackcat4866
09-09-2022, 03:04 PM
Thanks, L0rdC.
My machine is holding quality fine, and the cyan has returned to it's normal hue. =^..^=
tulintron
09-09-2022, 07:42 PM
Here we already have 04 with
DV610. Composition is different, but comes without problems for 05 months. Average of 30k/month
wjurls
09-09-2022, 10:19 PM
I would imaging that the steel powder base is the same with a different toner mixed in. Like Blackcat noted above, once the premixed toner gets cycled out you are left with a useable developer.
How sad that Konica has turned us all into Jr scientists.
L0rdC
09-12-2022, 07:39 AM
KM was my preferred printer manufacturer, after all these "accidents", for me KM has proven to be an unethical company and with which I no longer like to work, the machines that we are putting into maintenance are no longer KM
blackcat4866
09-23-2022, 12:57 AM
Just to include some useful details:
DV-614C has 630gms of developer mix only, 7.5gms for the bag only.
DV-610C has 1100gms
wjurls
09-28-2022, 06:30 PM
DV-610C has 1100gms
Thanks for that. You can almost do 2 complete dev changes on the C1060 with one box of DV610.
adeyemi
09-22-2023, 08:20 AM
Has anyone experimented with dv-614 on the high chroma machine? What is the effect on photo prints? Dv-615 is increasingly more difficult to source here
