View Full Version : CE Password Reset FYI
Markks
08-20-2022, 01:35 AM
on the bizhub 4050,bizhub 4750,bizhub C3350,bizhub C3850,bizhub C3850FS
1. Select Administrator Setting
2. Using the numeric keypad enter 12345678
3. Select Security Settings
4. Select Security Details
5. Select Initialize
5. Select Restore system
6 Select OK
7. The machine will automatically reboot.
8. Select Menu - Touch Menu.
9. Select counter - Touch [Counter].
10. Select Keypad
11. Using the numeric keypad enter Stop 00, Stop 01
12. Enter CE password 92729272
13. Press OK
On other KM machiness see screenshot
54400
techsxge
08-22-2022, 11:55 AM
Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers. Don't let this see any of my "tech" customers.
adecanmin
08-22-2022, 12:30 PM
6 Select OK
10. Select Keypad
13. Press OK
54400
Will this work on the c3851?
techsxge
08-22-2022, 12:52 PM
probably.
otphas
08-26-2022, 11:52 PM
If your Admin mode pass is also changed what is the procedure ?
Markks
08-27-2022, 02:12 AM
you can reset admin password in service mode . you can also just just unlock the admin lock out under enhanced security mode
Zoran
04-15-2023, 12:45 AM
Maybe I can help you with my modest knowledge.
The procedure is shown for the bizhub pro 951 and is the same for the c6000 c7000.
You must be a skilled technician and confident in yourself, otherwise you will burn the machine.
1. Remove the back cover of the machine.
2. remove the plate shown in the picture.
3.unload nvram
4. with the parts thus removed, enter the service mode
Hold down the bediener-zahler button and turn on the main switch
5. when you have entered the service menu, carefully return the nvram to the bearings.
6. press stop - 0 - C and turn off passford
I can send you videos of me doing it
https://www.youtube.com/watch?v=iNVzuQpFN70
This reset method keeps all settings, serial number of the machine and dials.
Another way is to contact a Konica minolta service engineer who has access to the database.
Namely, each machine has its own security code, which is linked to the serial number of the machine, through which you can enter the service menu and turn off the password.
