View Full Version : cs6500
Marc J
01-25-2009, 11:54 PM
I have a machine giving a 2213 code which is for the cyan drum. The blade does not flip and it can be reset. It is most noticable when running 12x18 heavy stock duplex. I have changed the drum drive motor and the printer control bd. I'm going to change the whole drum drive unit for the cyan drum next. Has anybody had this problem before?:(
random
01-26-2009, 08:18 AM
I suggest you do the (t/f) belt line speed before you start. If the problem persists swap the yellow drum shaft assy. I have had this but it was quite sporatic and ended up being the printer control board (upper right back of the machine)
tervel12
01-26-2009, 01:25 PM
Check your firmware version as well. There was a special release, 30-GCA, that allows you to change several dipswitches to alter the drum speed.
random
01-26-2009, 05:48 PM
Oh yeah! Completely forgot about that! Definatly check out the tech bulletin with regards to drum speed and those codes.
drodas78
04-26-2009, 12:41 AM
Can you send me that tech bulletin? I'm having same trouble. How do you fix it?
tnx
ciuffe
05-04-2009, 10:44 PM
I have the same problem,
could you send me this technical bulletin?
Thank you
Vesigoth
05-05-2009, 06:51 PM
hi guys. my c6500 is giving me an sc-2211 & I also have a c500 with sc2701. please help
holger
05-05-2009, 06:57 PM
When the drum motor/Y (M14)
was ON, M14 abnormality
detection signal was continuously
detected for the specified
time.
Main body
stops immediately
and main
relay (RY1) is
turned OFF.
Printer control board (PRCB)
Drum motor /Y (M14)
tervel12
05-05-2009, 08:37 PM
For the c500:
Solution ID TAUS0640742EN* Solution Usage 3
Description
F27-01, F27-02, F27-03, or F27-04 when performing L-detect.
Solution
CAUSE: Improper charge corona installation is causing the developing unit to purge the developer and collect it in the toner collection bottle.
SOLUTION: Properly reinstall the charge corona. If the developing unit is not fully purged, empty it and recharge the unit. Inspect the drum for the affected
color and the transfer belt for damage. Replace the drum (Item #960897) or transfer belt (p/n 65AA26420) if they were damaged by the developer. Perform
the required adjustments after changing developer.
For the c6500:
The C-2211 is usually caused by the yellow blade flipping.
Install the new DU-102B which is supposed to correct this issue. If the problem is not the blade flipping, then it is possibly a drum speed error. If that is the case then check out this bulletin:
DL(Download Library)
[ID-No.] ID-No.DLBT0800817EN00
Publisher
[Company] BT
[Group] BT_Service_PP1
Contents
[Original Doc. No.] DLBT0800817JP00
[Open Date] 2008/03/14
[Doc. Language] English
[Doc. Priority] Normal
[Program Category] Special Program
[Product Name] Color MFP : ineo+ 6500
Color MFP : bizhub PRO C6500P
[Option] PF-601
[Subject] [MFP Fw Ver.GCC-30]To prevent the soilage of the Side2 due to the insufficient cleaning of
the adjustment, to prevent the frequent C-22XX (drum drive error) and countermeasure
against the C-03XX (assist fan error) with PF-601.
[Content]
1. Release version and download file name
The newly released program version and download file name are as follows.
Model Spec Program
name ROM name Version File name Note
bizhub PRO A03U0Y0_00C1_GCC_3000.bin Program file
C6500
C6500P
ineo+6500
All
Print
control
program C GCC-
30 A03U0Y0_00C1_GCC_3000.sum Checksum
file
[Download file name]
The above programs are combined for each destination and compressed with the following names.
C6500_C1_GCC30.zip (for All)
[File configuration]
The file configurations are as follows.
C6500_C1_GCC30.zip +---PRO_C6500+---B
+---C +---A03U0Y0_00C1_GCC_3000.bin (This release)
+---A03U0Y0_00C1_GCC_3000.sum (This release)
+---F
+---H
+---I +---I0
+---I1
+---I2
+---I3
+---I4
+---I5
+---J
+---N +---N1
+---N2
+---R
+---S
2. Where changed
This firmware is released for the following purpose.
a. Newly added function/change of specifications
[bizhub PRO C6500]
1) A new dipswitch has been added to prevent the soilage of the Side2 due to the insufficient cleaning of the
adjustment patch.
DipSW 20-7:
0 = Usual cleaning
1 = Cleaning more times
2) A new dipswitch has been added to prevent the frequent C-22XX (drum drive error).
DipSW 21-6, 21-7:
0, 0 = Default
1, 0 = 0.1% up
0, 1 = 0.2% up (recommended)
1, 1 = 0.3% up
b. Correction of malfunctions
[bizhub PRO C6500]
1) Countermeasure against the C-03XX (assist fan error) with PF-601
3. Restrictions
1) This firmware is for the new type memory control board (A03UH04013). If old type board is installed, replace to
the new type before installing this firmware.
2) If the dipswitch 20-7 (to prevent the soilage of the Side2 due to the insufficient cleaning of the adjustment patch)
is set to 1, the duration of adjustment becomes longer. (Usual cleaning= 3 sec, Cleaning more times = 6. sec) and
productivity decreases.
3) Countermeasure against drum drive error (fine adjustment of drum speed): To enable the effect of the dipswitch
21-6, 7, the belt line speed adjustment value should be within the range -5 to -20. Please check the value. If the
set value is out of the range, the effect of special ROM cannot be achieved and C-22XX may occur.
How to check the belt line speed:
[Service mode] => [01 Machine Adjustment] => [01 Printer Adjustment] => [08 Belt Line Speed Adj.]
4. Programs to be applied at the same time
5. How to install
a. How to update the firmware
1) ISWTrns version that supports related unit of bizhub PRO C6500 is Ver. 3.65 and later. .
When performing ISW to rewrite C6500 engine programs, select the model “C6500”.
Please refer to the Service Manual for the detailed procedure.
2) When you use Service Port to update the program, copy the whole folder of the firmware, which is shown as
“PRO_C6500”, onto USB memory stick. Please refer to the service manual for the update procedure.
b. How to check version
1) You can check the ROM version in Service mode => 08Firmware Version => 01ROM version.
Print control C: A03U0Y0-00C1-GCC-30
6. Remarks
1) This function will be applied to the next mass production firmware and the release will be June 2008 or later.
Model Program name ROM name Version
Image control
program
I0 (I1-
bizhub PRO I5combined) G00-30
C6500
C6500P
ineo+6500 Print control program C GCC-
30
FD-501 Multi Folder control
program H G00-30
SD-501 Saddle stitcher
control program B G00-30
FS-503 Stapler control
program N1 G00-26
FS-607 Stapler control
program N2 G00-30
FS-520 Stapler control
program N2 G00-30
LS-501 Stacker control
program S G00-30
RU-503/504 Relay unit control
program R G00-30
PB-501 Perfect binder control
program J G00-20
DF-609 ADF control program F G00-10
[Attached Files] C6500_C1_GCC30.zip
PRI_DLBT080817EN.doc
[Rev. Memo]
[Version] GCC-30
[App/Drv Language]
[Information Type] Program
[Subinformation Type] Firmware
[Program/Manual/
Training Material Type]
Complete(Program)
Hope this helps you out,
tervel12
