View Full Version : FS-539 Mandatory Modification Bulletin Issued by KM
femaster
09-27-2022, 08:50 PM
KM just issued a technical bulletin for mandatory modification of the FS-539 finishers. Apparently they were assembled incorrectly at the factory which results in misaligned output when stapling. It looks like it's going to be a fun modification. Not looking forward to doing this at all...
tsbservice
09-27-2022, 09:19 PM
Thank God we don't have one. Looks like a lot of fun involved-springs, grease, tight spaces and possibly damaged FS. What a great QA though!
L0rdC
09-28-2022, 07:35 AM
I'm not surprised at KM, really...
copyrooks
09-28-2022, 11:19 AM
The techs should get the reimbursement directly from konica. Waste of time
mojorolla
09-28-2022, 01:51 PM
$108, great compensation KM. They should have set fire to the entire i Series machines instead of their toner plants.
Par for the course with KM as of late.
blackcat4866
09-28-2022, 02:40 PM
Can be the defect be seen before you start disassembly?
It would be really disappointing to spend two hours disassembling the finisher ... only to discover that you never needed to. =^..^=
occus
09-28-2022, 04:21 PM
I think so.
Have a look to the right roller from outside. The passiv white roller should have a distance from the right margin... you should see the metall axis. If not then the roller are misalignet to the grey active rollers with the spikes.
54799
Or on Pic 2 you can check the distance of the 2 middle rollers, they should be not to close to each other.
54800
blackcat4866
09-28-2022, 04:46 PM
Is that the metal guide shaving off the rubber? That's fairly obvious. It sounds like you need to have a new set of rubber rollers on hand before doing the bulletin. Thanks, occus. =^..^=
rrrohan
09-29-2022, 06:04 AM
you can by serial number
FS-539
AAR4WY1031758 - AAR4WY1035182
FS-539SD
AAR4WYA022846 - AAR4WYA025403
femaster
09-29-2022, 06:21 AM
There is a serial number range listed in the bulletin. Also, any that were produced after the problem discovery, and have the rollers installed properly, will have a "green label" attached to them.
occus
09-29-2022, 09:56 AM
Ah it's only dirt... There is enough space... maybe after the modification http://www.copytechnet.com/forums/images/icons/icon12.png
As they always write so beautifully "Reassembly the FS-539 by reversing the installation instructions"
