zodiaco
09-29-2022, 06:17 PM
Dear all,
The fax in my 283 started acting up. It's a well maintained low count 283 (97k pages as of today). Everything worked fine until 2 weeks ago, when the fax stopped working.
I am using a VOIP line from ATT.
Some days everything works fine, some days I won't hear a dial tone when I press "off hook" and no faxes are sent or transmitted. There is no error code.
If I reset the ATT modem, it works again for a little while, which is even more puzzling.
I have not made any changes to the fax setup inside the machine, however, we just recently switched to VOIP from a normal, "analog" line.
I am at loss as to what to do.
What would be your troubleshooting recommendation?
I am very grateful for any leads you may have for me.
Thank you!
Darius
Thank you!
Darius
