wwandrei
01-27-2009, 08:02 AM
Hello. I have a KONICA DP 85 printer with IP-602 controller. Bellow are the firmwares and softwares that are installed on the controller. I must say it`s a clean install of the software on this controller:
IP FW Vers: 26.4.0
NIC FW Vers: 6.29
VxWorks: 5.4.2
Sys Vers: 26.4.0
IP PCL Vers: 6.0.21
IP PS Vers: 6.1.1
The problem is that the IP-602 prints very slow any kind of documents but especially pdf files. I must say i`ve tried all type of drivers I could find on konicaminolta website, also tried it on different Operating Systems (XP, Vista, 2003 server), I did all the possible combinations from driver but still works very slow(the transfer of the document is about 64kb/3 sec ... very slowww). The network is tested and works fine.
The controller has 384 MB ram and 2GB HDD(I put additional RAM to see if that was the problem but didn`t solved anything).
FW 26.4.0 for IP-602 is the latest and the only fw I could get and it was installed with 13 floppy disks.
Did anyone meet this problem? Can u help me with any suggestions?
IP FW Vers: 26.4.0
NIC FW Vers: 6.29
VxWorks: 5.4.2
Sys Vers: 26.4.0
IP PCL Vers: 6.0.21
IP PS Vers: 6.1.1
