View Full Version : C6000 corrugated paper
Konica C6000
10-19-2022, 11:47 AM
Hello!
I have a Konica C6000 machine and when printing 80gr paper, the paper becomes wavy. What might be the problem?
5503255033
Thanks in advance for your help.
tulintron
10-19-2022, 12:31 PM
Good Morning. Check the fuser unit and the paper exit unit
Konica C6000
10-19-2022, 02:17 PM
Hello!
I checked the circled units. The print setting is face up.
It very rarely prints without waves, but usually there are 2-3 waves in the sheet.
55037
tech51
10-19-2022, 06:39 PM
The entry guide to the fuser with the brown looking coating on wears and can cause this.
Konica C6000
10-19-2022, 07:20 PM
Do you think about the lower fusing roller?
I have a piece of them, i will replace tomorrow.
Thanks!
joaopauloooo
10-27-2022, 06:59 PM
Check if the Adhesive tape of the Teflon tape is worn.
The part you should be looking for this is the "Fusing separation assembly" Part number: A1DUR74H00
Papel Saindo Ondulado - Konica PRESS C6000 - YouTube (https://www.youtube.com/watch?v=x6O4AkZ2jHc)
Another thing that could cause this is humidity, try to see if it happens with low humidity paper.
Synthohol
10-28-2022, 02:53 AM
check these gears too, there are one way gears and can crack or slip.
https://www.copytechnet.com/forums/attachment.php?attachmentid=55198&d=1666921957
Toxic
10-28-2022, 07:57 AM
If you have finisher connected to machine try to open door during printing and check at what section of process paper get wavy, could be finisher problem.
Konica C6000
11-06-2022, 12:35 PM
Thank you all for your help!
Yerterday a replaced the lower fusing roller, and the problem is solved. I checked the gears too.
allan
11-06-2022, 04:17 PM
One of the one way bearings on the fuser exit get installed wrong way round and has the same result.
