View Full Version : Konica C6500 Very Strange Error
I am getting a 2813 error on my Konica c6500
My main concern is that its related to the 2811 board code, as my common solution PDF doesn't show me any fixes or even that code!
please help me, I am at wits end.
seniortech
01-27-2009, 08:21 PM
Solution ID TAUS0703438EN* Solution Usage 1
Description
C2811, C2812, C2813, or C2814 error code.
Solution
CAUSE: The drum potential sensor for yellow/magenta/cyan/black (respectively)may have a film of toner dust on it affectingsensitivity.
SOLUTION:Clean the sensorand if the problem persists replace the HV detecting sensor assembly (p/n A03UR73600).The sensors for the 4 colors are
interchangeable.
harry2007
01-29-2009, 07:07 PM
the same code may apear if you deleted counter life of the drum(s), or the drums are very old.
Try to perform drum potential adjustment.
if don't work change the drum(s)
or realy drum potential sensor are broken (1% prob)
glennsan
01-30-2009, 03:47 PM
C-2813. From service manual: In charging potential control, drum surface
potential/C was out of specification.
Printer control board (PRCB) Drum potential sensor bord/C (DRPSB/C
Drum potential sensor /C (DRPS/C)
