View Full Version : Miscellaneous BH 4750 maintenance kit
Acadien
11-02-2022, 07:55 PM
When Maintenance kit counter is at 0 % do you replace it or just reset counter, everything is working fine.
davidmtupper
11-02-2022, 08:06 PM
IIRC those are reset by replacing them, not sure if you can manually clear the counter.
strider5555
11-02-2022, 10:05 PM
If the fuser is still in good shape, and no other jamming or copy quality issue are present, just reset the maintenance counter in service mode, counter, life, new release.
copyman
11-02-2022, 10:37 PM
2. Scheduled maintenance
The control panel displays an "MAINTENANCE KIT LIFE" error when it reaches 200K page counts. It is necessary to install the appropriate
maintenance kit to maintain the print quality and reliability of the printer. Reset the maintenance counter after replacing the maintenance kit.
2.1 Maintenance kit
Part number and kit Contents
Maintenance Kit • Fuser
• Redrive assembly
• ACM pick tire
• Transfer roll
• Separator roll assembly
• MPF pick roll and separator pad
When performing the 200K scheduled maintenance procedure, the following areas should be cleaned of media dust and toner contamination:
• Media trays
• Imaging unit area
• Transfer roll area
• Duplex area
• Standard bin
2.2 Resetting the maintenance counter
Always reset the maintenance counter after installing the maintenance kit.
To reset the maintenance counter:
1. Call the Service Mode to the screen.
2. Performing “New Release” of the “Maintenance kit” in life counter of the Service Mode will reset the life counter of the maintenance kit to
zero.
Hansoon
11-03-2022, 04:31 AM
Depending on the customer and the situation, but the first thing I do with our rentals is resetting that counter and see how it develops. :cool:
Payable customers, it's a “little” different, of course.
Hans
Sysco
11-03-2022, 01:17 PM
Hans
I like it. :cool:
