View Full Version : Toshiba Firmware
gregrcs
11-13-2006, 07:32 PM
I need the latest firmware for a Toshiba e3511. Any help would be greatly appreciated.
Thanks,
Greg
ToshibaGuy
11-15-2006, 03:22 AM
Thanks,
Greg
I tried to upload the usb update file but it is too big (over 30mb) so PM me with your email address and I will get it to you.
Claudio_
04-24-2008, 10:41 AM
Dear Toshibaguy.
Please send even me the firmware for estudio 3511 (I think is the same firmware for 4511)
My email address is indriti_ @hotmail.com
I appreciate very much your help.
checazo
07-02-2008, 05:26 PM
ear Toshibaguy.
Please send even me the firmware for estudio 4511
my mail: checazo@hotmail.com, checazo66@latinmail.com, supercopy@gmx.net
thanks
esam ramadan
08-08-2008, 10:37 AM
please send me too mr the firmware 4 4511
esam_ramdan2002@yahoo.com
techguys
11-05-2008, 12:10 PM
Would it be possible for you to send me a copy of the firmware too. I have had the CEB0 error and replaced the clutch. I'd like to update the firmware too as I understand there is a patch in it for this error.
techguys@engineer.com :D
yormets
05-22-2009, 08:01 PM
Can I get a copy of the latest firm ware for the E 3511.
Toshiba911
05-23-2009, 01:33 AM
Dear Toshibaguy.
Could you send me the firmware for estudio 3511/4511 too
My email address is: shaphn@yahoo.com
sjinachandran
12-31-2009, 07:30 AM
Dear toshiba guy,
i need e-161 firmware, pl send it to my id sjina_72@yahoo.com.
MiguelRT44
12-31-2009, 05:43 PM
I also need the firmware I could send to my email or give me instructions to get my email is msosaster@gmail.com thanks
gfady1
02-12-2010, 03:37 PM
Hi all
i have 2 problems with my toshiba 4511 and i need someone help
FIRST: when i open my toshiba i find language (svenska ) and i can't change it from the language menu as there is no other language .. and when i went to the settings 08-220 i can't change No. 5 language to any other language (when i change to No. 1 and restart the machince i find is changed automatically to No. 5 again)
SECOND: when i give a print order from the computer using any connection (USB , Parallel or Network) the data led keeps blinking but no printing is there and even when i go to job status i find no orders there,, and the copier can't do any thing till i restart it..
Noting that all process of coping is working super fine ..
Can any body help me Please .. i think it needs a firmware upgrade but i can't find for more than 4 month till now thanks in advance
Fady Gendy
Gfady1@hotmail.com (Gfady1@hotmail.com)
I also need the firmware for 3511\4511 and 350\450 my email mfag2001@hotmail.com
regards
cooked
02-21-2010, 06:49 AM
Hi there,
I am looking for firmware for a Toshiba e-studio 350.
Current Details from Function List
S/N CPE419324
F/W Ver T360SY0X320
M-Rom 360M-11
S-Rom Ver 360S-10
I have a problem where I can ping the printer but can't access web functions.
Driver sees printer but can't print. I have put into trial mode to try to sort this out before purchasing a Print/scan enabler.
USB/CX printer ports- computer can see ports but not print to it.
I believe either reloading the firmware or upgrading the firmware will help sort the problem out.
Copier works as a copier fine.
Any help appreciated
Doug.
Mr Spock
02-22-2010, 12:35 AM
Hi there,
S/N CPE419324
F/W Ver T360SY0X320
M-Rom 360M-11
S-Rom Ver 360S-10
Doug.
On this model, if you do not have the print enabler then you can not print/view the web page of the machine. If it works in trial mode then when you put the enabler in then you need to change nothing...
Also since you are at v320 the pm counters will not function correctly until you go to at least version 321. The latest version is v4006 on the es350 and v340 on the es352/353 series.
jinxs
02-22-2010, 02:01 AM
Hi there,
S/N CPE419324
F/W Ver T360SY0X320
M-Rom 360M-11
S-Rom Ver 360S-10
Doug.
when you say "can't access web functions, do you mean you cant access Top Access?"
if not, try to disable you antivirus to see if its blocking the print.
i had a case where an antivirus blocked me from accessing it
cooked
02-22-2010, 10:30 AM
TampaFi
1. To upgrade V320 to 321 or later I have read on these forums that you need to upgrade from one version to the next in steps. I assume you can't just go from V320 to V4006 in one go.
2. Where can I get the various firmware versions for this unit. I have searched the net for the past week looking for firmware and descriptive instructions/proceedure for loading firmware but have come up blank. I assume the code is loaded onto a usb stick and 0-8-797 Firmware Download (which is set to 0 at present) will flash the code onto the unit.
Jinxs
Yes I can't access Top Access. I can ping the IP address but when I try to access from Internet Explorer (http://192.168.0.11) it just says waiting for http://192.168.0.11 then after a period of time Internet Explorer cant display this page message. I have tried it on XP Home, XP Pro ( New install) and Win Server2003 Three different machines with the same result. Antivirus is not a issue.
Another thing (and this may be a red herring) 0-8-933 Web data whole version = ----
If I try ftp ftp://192.168.0.11 it comes up with a username/password challenge screen. Not sure what username/password to use. Have tried admin/aministrator/public etc and 123456 but can't get past this screen.
Rds
Doug
Mr Spock
02-22-2010, 11:34 PM
TampaFi
Jinxs
Rds
Doug
I would suspect that without a value in the 08-933 that you have an incorrect or incomplete firmware on the machine. Also here in the USA there is no version 340 for this machine. I can get the USA version 4006 which includes the download instructions, but I do not know if it will work where you are at.
cooked
02-24-2010, 09:05 AM
Thanks Mr Spock.
I have come to the conclusion that a firmware reload is necessary. I am sure I read that 4006 was also loaded on machines in Australia ( our nearest neibour).
If you are able to send me the file that would be great. Do you know what the file size is? Will it go by email or is it too big?
email :- d-jcooke@ihug.co.nz
Doug
Mr Spock
02-25-2010, 12:00 AM
The file is 45 meg in size so most email will not allow it to go through. Even Gmail (googles mail) has a limit of 25 meg.
By the way isn't Australia your LITTLE neighbor????
Let me see if I can get it to you another way.
knightfall
02-25-2010, 02:00 AM
It's about time someone notices that 45 mb won't fly through the email system, try using YouSendIt: Online File Sharing and collaboration with FTP Replacement - Send Large Files and Email Attachments with Managed File Transfer Solution (http://www.yousendit.com) you can sign up for free account. Good luck.
cooked
02-25-2010, 02:57 AM
I have set up a ftp server on the workbench in the workshop to rx the file. will PM the address and access details.
Rds
Doug.
sdrawkcab
02-26-2010, 07:25 PM
There's a Toshiba branch in Auckland, why not contact them for help.
cooked
03-01-2010, 10:36 PM
Thanks sdrawkcab.
I have previously spoken to Toshiba in Auckland. They were not very responsive to my last request.
I have been fixing Computer/electronic/industrial/office equipment/phone systems etc for over 30 years. If this one was for a client I would have just sent it to them, however this one is my own private project. I am trying to set it up so my disabled wife can print of her manuals/books/newsletters from the computer.
I will use Toshiba as a back-up when I have run out of options.
gitana1983
03-26-2011, 04:26 AM
Hey i was wondering if you could help me out and
email me the toshiba 3511/4511. Firmware.
I would appreciate it soo soo much. Thanx
hoanphuc20033
03-27-2011, 09:41 AM
help me with him toshibaguy! I need firmware of the machine and service handbook toshiba 451c / 3511. if so, can you send me are not I will call him toshiba firmware 450/452. I look forward to working with
thank you so much
if you is any forum they can talk to yourselves
yahoo : hoanphuc20033@yahoo.com
gmail: vannghiep25@gmail.com
JustManuals
03-27-2011, 09:04 PM
Need need need. 1st post and you need something. What is it you offer to the forum?
hoanphuc20033
03-29-2011, 12:23 PM
please help me with his dear toshibaguy
They also are in need of service handbook and firmware toshiba 4511/451c
thank you so much
ymail : hoanphuc20033@yahoo.com
hoanphuc20033
03-30-2011, 11:50 AM
why did not anyone help me with
I'm very need it
JustManuals
03-30-2011, 11:43 PM
Maybe it has to do with he fact that your 9 posts on this board are all asking or begging for something. What is it YOU bring to the forum?
hoanphuc20033
03-31-2011, 12:32 PM
not like that my friend!
in Vietnam because his language is not very fluent, so the sharing of experience is hard for me
I write this message on google but it translated into your
foreign language when you say your better off I'll share with you what I know
hope people understand me
a half times sincerely thank
edward16
10-14-2011, 11:32 PM
dear TOSHIBAGUY, i read all the thread about you having a firmware for tosh. Im just thinking if you also have a FIRMWARE for Toshiba e studio 3100c with Fiery x3e+ print controller ( built-in). Its an old machine buts its so effiecient not until it won't print anymore. If you ahave a firmware for this old baby, i would love to have it and will be greatly appreciated. PM me or email me if there will be any cost at your end. Willing to pay in a reasonable price. Thanks in advance. My email add is edwardt@freshpoint.org
hawkeye
03-06-2012, 06:08 AM
Hi guys, i have a e3511 with firmware ver T350SY0X300. just wondering if there is newer ver for the beast? I am having a few problems printing and hoping that the new frimware might help.
if you can help my email is hawkeye_870@hotmail.com
(hawkeye_870@hotmail.com)
thanks in advance
Outlander
03-06-2012, 11:46 AM
thanks in advance
Last official version for MJD is T350SY0E4006 since 2007
emujo
03-06-2012, 01:46 PM
I'm very need it
Bạn cần phải cung cấp cho một cái ǵ đó để diễn đàn này trước khi bạn sẽ nhận được bất kỳ sự giúp đỡ với các yêu cầu hướng dẫn sử dụng phần mềm và dịch vụ ... Và điều này có thể cung cấp cho bạn một số ư tưởng của bài viết của bạn trông cho chúng tôi. Tôi đang sử dụng vietnamse tiếng Anh phiên dịch (google). Tôi không có ư tưởng làm thế nào nó sẽ đọc cho bạn, nhưng tôi hy vọng nó cũng khủng khiếp như của bạn cho chúng tôi. Emujo
I've always wanted to do this so I can show just how bad the translation can be. Emujo
hawkeye
03-06-2012, 09:48 PM
Thanks, I am having trouble printing and found a driver site that states (The e-Bridge controller must be at firmware version
T350SY0X4006 or higher to be compatible with following drivers.)
does anyone know what the last letter difference between T350SY0E.... and The T350SY0X.... are. Are they a country code?
the original firmware is T350SY0X300.
Which firmware do I need?
TheOwl
03-07-2012, 11:30 PM
You need v4006.
What are your exact printing issues?
hawkeye
03-07-2012, 11:58 PM
You need v4006.
Every time I send a Print the Print Data light flashes and flashes and Flashes and nothing happens. Machine won't shut down after that. Turn off from switch.
I have tried through the USB network and Parallel port but all doing the same issue. Yet the copies are perfect and scan is OK as well.
Also have tried many different drivers.
All I can say is there are WAAAAAAYYYYYY too many 35lemons(3511) left in the world to ever be a good thang..!!!!
TheOwl
03-08-2012, 12:21 AM
That can also be a RAM issue.
hawkeye
03-08-2012, 12:35 AM
This machine was given to me as the guy couldn't fix it.
When I first got the machine it would not boot and no screen so I took 1 ram stick out and it booted after that.
The Ram was a mismatch.
TheOwl
03-08-2012, 12:38 AM
Did you replace the RAM or just leave it out?
hawkeye
03-08-2012, 01:13 AM
I just took out 1 bank out of the 2. It now has 128mb in 1 bank
I think the guy that gave me the machine tried to upgrade and added the extra.
TheOwl
03-08-2012, 01:26 AM
From memory, you need all the RAM slots populated as each stick of RAM performs a different function and it would sound like you have removed the print memory which causes the issue that you are experiencing.
hawkeye
03-08-2012, 01:36 AM
I will try to find an extra stick. Do you know if that is standard PC ram PC133?
TheOwl
03-08-2012, 01:40 AM
Can't remember sorry.
It may look like standard RAM, but sometimes it can be vendor specific.
hawkeye
03-08-2012, 09:46 PM
Thank You TheOwl
Looks like you helped me solve this problem. The guy that owned the machine has swapped the main memory 128mb dimm with the 256mb NVRAM.
Maybe still worth upgrading firmware from T350SS0X300 to T350SY0X4006. If someone can help me out with this Version of firmware it would be appreciated.
Thanks again
masuta
09-01-2014, 08:53 AM
Hi everyone,
I'm also attempting to locate the firmware update files to update my toshiba 3511 from T350SY0X200 to something a little newer. Are the files still available anywhere?
Thanks for any help.
Copafield
09-10-2014, 03:49 AM
I am chasing the firmware for the 3511 myself. I had a hdd problem which I have replaced, initialised and now believe I have to put the firmware on but please correct me if I'm wrong. I'm not new to PC's and printers but this is the first time I've tackled a large photocopier. If I knew it was definitely the only problem I'd just pay the Toshiba guy to come out and do it but I don't want to waste the money if there's further problems with the machine.
