View Full Version : Bizhub C7000 Error code C- D0E2
tulintron
11-04-2022, 08:01 PM
Good afternoon people.
I have bulletins saying how to fix the FW GMO-40. I don't have it in my data.
Would anyone kindly help?
Thanks.
tulintron
11-04-2022, 08:13 PM
We update the printer, we update the controller, we replace the HDD (P), we format the HDD (P), we change the memories of the PH-102 kit.
The controller had an error in the update - SC 30-003.
The controller does not complete the update.
Synthohol
11-05-2022, 11:54 AM
Error
C-D0E2
Root Cause
C-D0E2 after installing the PH-102/HD-514.
Workaround/Fix
PROBABLE CAUSES:
1. One of the two Memory Control Boards is not seated correctly.
Remove and reseat the boards.
2. Memory Control Board/1 and Memory Control Board/2 are installed in the incorrect positions on the PH-102 board.
Reinstall the memory control boards in the correct positions. Please refer to the attached PH-102 install guide for more detailed information on board locations and the correct installation positions. To view the PDF, you may need to download a free copy of Adobe Reader®.
tulintron
11-07-2022, 11:22 AM
Good Morning. Exactly, Synthohol. Procedure completed, but the printer persists in the error. Two bulletins I have say about this FW I don't have. It was my hope. I removed all the parts involved and brought it to the laboratory. I will mount on another printer now and later have the answer. I let you know
tulintron
11-07-2022, 03:09 PM
The error is in the controller IC-601 SSD.
Has anyone ever needed to replace this SSD at some point in their life?
