View Full Version : Activation Code for AirPrint2.1
B0265
11-08-2022, 02:58 PM
Does any of you have the AirPrint 2.1 activation code for a Ineo +450i?
emujo2
11-08-2022, 04:28 PM
Km has not released this yet..Drop the function version down to 2.0 E
Synthohol
11-08-2022, 11:01 PM
CAUSE: Function version 2.2 added support for Air Print version 2.1. A certificate is required from Apple development to allow the functionality on the device.
SOLUTION: Change the Function Version to 2.1 using software switch settings.
[Service Mode] -> [System 2] -> [Software switch Setting]
Software switch number 25 to 0x20 (HEX 20)
Air Print is still functional using version 2.1.
Markks
11-09-2022, 12:13 AM
Airprint is now available with firmware G00-M2 and higher current version for the 450i is G00-N4. you can set switch 25 to hex 30 with no problem
copytechtrouble
11-11-2022, 09:14 AM
the latest firmware (N4 and M2 i believe) have this issue resolved but if you don't have access to the firmware there is a code on this thread that will enable airprint.
https://www.copytechnet.com/forums/konica-minolta/163161-develop-450i-function-code-airprint-2-1-a.html?highlight=airprint+forum%3A40
tsbservice
11-13-2022, 05:56 PM
I tried to send you a message but your PM is full. Try this:
KVX4RPQ7G7FQQRQPC3F6XRWYM2G3TXVV
B0265
11-15-2022, 12:51 PM
Thanks for the code. I can't delete any messages in my inbox, it says "You have 65,535 total out of 100 allowed."
At the moment we can't to upgrade to M2 or N4 on this MFP.
