View Full Version : CQ BH 226i Copy/Scan Overlapping Issue
subhashck
11-22-2022, 06:37 AM
It's a new BH226i MFP. Checked the Scanner Harness. Found OK. in Scan/Copy there is Overlapping in the left side. Need help and suggestion. Please find the attached Photographs of the original and copy output. Same thing happens in case of Scan also.
Subhash Chandra Kalita.
techsxge
11-22-2022, 08:14 AM
Check drum unit and maybe transfer belt
subhashck
11-22-2022, 10:39 AM
Thanks for your reply. But the problem occurs in scanning also. Normal print from PC is OK. Counter Print List / Demo Page is OK.
subhashck
11-23-2022, 08:24 AM
Please....anyone to provide solution or any hints to resolve the problem.
techsxge
11-23-2022, 08:28 AM
clean scanner unit and scanner glass?
blackcat4866
11-23-2022, 01:47 PM
Clearly, it's an image processing error of some sort. I've seen this exact sort of defect on the PRESS 1052, which uses an LED exposure/printhead.
Most likely, there is not anything mechanically wrong with the scanner, it's the electronic image processing that is creating this fault. =^..^=
techsxge
11-23-2022, 03:17 PM
you are right, must be some sort of "software" or eletronic issue. Maybe update firmware?
subhashck
11-23-2022, 03:29 PM
Thanks a lot for your valuable input. I'll check and confirm.
subhashck
11-23-2022, 03:30 PM
tsbservice
11-23-2022, 09:28 PM
Unfortunately this is low end KM B&W A3 lineup.
Still POS.
Try to replace CIS module
