Bocian
11-25-2022, 01:27 PM
Hello everyone.
I've just run out of ideas to get this to work so I've decided it's time to reach for help.
We've go an C220 with firmware below:
55622
I've setup scan to email back in 2018 (using created shared mailbox in Office 365) and it was working fine until somewhere around february 2022 when suddenly it stopped working.
Since then every job is ending with an error "server connection error" (of course nothing was changed on the device).
I've read how things should be set and I think that we have everything right:
[Machine] -> [Machine Setting]:
Under Administrator Registration:
Administrator Name: C220
E-mail Address: our_company@our_domain.com
Under Machine Address
Device Name: C220
[Network] -> [E-mail Setting] -> [E-mail TX (SMTP)]:
SMTP Server Address: smtp.office365.com
Start TLS
Port 587 (also tried 25)
Admin E-mail Address is copied from Machine Setting so it's correct
Device Mail Address: our_company@our_domain.com
SMTP Aithentication checked
User ID: our_company@our_domain.com
Password: correct password to shared mailbox
55623
Of course on this screenshot I've changed our proper e-mail to: our_company@our_domain.com
So everything seems fine and set as should be (this setting was working for almost 4 years)
After searching for a solution I've read that there should be a checkbox by the TLS 1.2 Under [Security] -> [PKI Settings] -> [SSL Setting]
The problem is that I don't have any of SSL/TLS checkboxes:
55624
(When I change mode using SSL/TLS to Admin and User and Encryption to AES-256 those checkboxes also don't appear - even after powercycling the machine)
I've read that maybe first I need to create self-signed certificate but here I also see diffrence comparing to one manual that I've found here on forum.
I can only chose RSA-1024,2048 and DSA-512,1024,2048:
55626
But from one manual there should be RSA-2048_SHA-256
55627
When I've created a certificate I've lost the ability to login to the device via web browser due to ERR_SSL_VERSION_OR_CIPHER_MISMATCH
I was able to download Firefox version 1.0 that didn't had problem with this so I was able to login to the device.
Even then there were no SSL/TLS checkboxes in [Security] -> [PKI Settings] -> [SSL Setting]
The created self-signed certificate automaticly was set to default one so I was unable to delete it to bring back the ability to login from newer versions of web browsers...
I've had to do a factory reset to the device to delete this certificate.
Do anyone have an idea how can we resolve the problem with scanning to O365?
55622
Device Name: C220
Start TLS
55623
55624
55626
55627
