View Full Version : Bizhub 420 freezing & Blank prints
Juggy
01-30-2009, 06:30 AM
Hi, we had installed a new Bizhub 420 which has done only 100 copies. we find following observations. when we try to copy using RADF / Platen we get a message copying please wait. Physical observation is Scanner lamp goes to the left extreme and get on and stays there no error code logged, screen freezes. Finally we need to switch off the machine. when we print meter reading or management list in service mode we get prints with out issues intermiddently. ie, some time it prints some times it prints Blank prints. The scanner assembly moves very well when we no non-image area setup . The machine has the latest Firmware Version 31. Some time the machine works fine for say 20 -30 copies and the problem repeats. If someone has faced such problem please help us with solution. we suspect OACB Board / NV ram .
pepper38_cnd
01-30-2009, 11:24 AM
Have you replaced the HDD and if it is connected disable SMB Direct Hosting.
buster68
01-30-2009, 07:55 PM
you suspect right!!! you have a bad OACB and NVRAM.
minoltaed
01-30-2009, 09:16 PM
One of the worst products to ever have minoltas name on it. If I can give you any advice it would be to throw it in the lake. lol
Juggy
02-17-2009, 06:17 PM
Hi sorry for the late reply. We replaced OACB board upgraded firmware. Observed machine for 10 day everything seems ok.
ni311
02-17-2009, 07:33 PM
You're invited to post here :)
http://www.copytechnet.com/forums/rants-raves-everything-else/508-copier-biggest-peice-crap-ever.html
