View Full Version : Miscellaneous AccurioPress c3080
CopyTech03
11-29-2022, 12:30 AM
Customer bought this machine online with numerous finishing options. The manual does not list which order to set them up. They are currently set up in this order after the main body: RU-518, IQ-501, RU-510, GP2, RU-510, LS-506, SD-506, and FS-532. It shows the first 3 options and then nothing after that. Does anyone know if this is the correct order and something not plugged in or if this order is incorrect?
blackcat4866
11-29-2022, 12:52 AM
I've never tried to string all these finishing options together.
Does your manual page look like this?: =^..^=
CopyTech03
11-29-2022, 01:15 AM
I saw a different page but similar. According to this I should have the accessories in the correct order. Must have at least the GP-2 not connected properly.
blackcat4866
11-29-2022, 01:17 AM
Let us know what you find. =^..^=
CopyTech03
11-29-2022, 08:46 PM
Was able to get the machine to recognize all of the components except it is showing Please confirm power cord and door of RU. I am assuming it’s referring to the 3rd RU in line since that is the one that doesn’t have any movement when the door is opened and closed, but still recognizes the components past it. Everything is plugged in (no power cord).
zayonc
11-30-2022, 12:02 PM
There is a suspicion that the RU-510 after G2 is superfluous
And we need 2 MK-737
zayonc
11-30-2022, 12:08 PM
55708
CopyTech03
11-30-2022, 12:43 PM
There are 2 MK-737 installed. Now I am confused. according to the main manual a RU-510 would be installed after G2, but according to these installation instructions there is no RU-510 installed after. It would just be the next component, which in this case would be the LS-506.
zayonc
11-30-2022, 01:12 PM
more or less like this
CopyTech03
12-01-2022, 01:09 PM
Thanks, that was it! Just needed to remove that 3rd RU. Now just need to figure out the jamming issue in the LS
CopyTech03
03-29-2023, 07:18 PM
You helped me out last time with this configuration. Now he wants to add a FD-503 for the post inserter option. Would it would with the current configuration and if so where would it go, or would we have to remove one of the RU in order to install the FD. Thanks
zayonc
03-30-2023, 03:44 PM
57562
FD-503 after G2, LS-506 must be removed. There is also a TU-510, they will like it.
