C258 wont recognize paper trays - cant print or copy
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 139
    I have a client with a c258 that wont recognize paper trays (tray 1, tray 2 and large capacity tray 3) and it wont print or copy.
    Rebooted
    The tray guides have been reset
    printer instances on PC's have been removed/reinstalled
    I'm at a loss as to where to go from here.
    Thanks for any help!
    • 22952
    Re: C258 wont recognize paper trays - cant print or copy
    Have you done a System Error Clear? =^..^=
    • tsbservice
      Field tech
      • 7927
      +1 trays may be isolated.
      • emujo2
        • Mar 2017
        • 1580
        Tray 3 would normally be a loose or not fully seated power or data cable, but all 3 trays lean towards a board issue..What about the bypass tray, does it work, and are Tray 1 and 2 seeing paper, just the wrong size? Do you have a light on the tray indicating paper status..I would not worry about printing until you get the copy working. E
        • FuserNoob
          Service Mgr, CISSP
          • Jul 2022
          • 139
          I have not, since it's not showing an error code, but I can try
          • FuserNoob
            Service Mgr, CISSP
            • Jul 2022
            • 139
            that's a possibility, as i replaced the caster base with the LC drawer
            I have not tried the bypass tray, but i will
            the trays DO NOT light up, as it looks like they are seeing paper
            and i agree, copy first - then print
            • emujo2
              • Mar 2017
              • 1580
              Tray light is only on when tray is empty. What happens when you open close a drawer? Do the trays rise? Does the LCD display reflect what the side guides are telling it?
              • progoffice
                • Nov 2008
                • 334
                If you disconnect the LCT you added from the machine does that make a difference on trays 1 and 2?
                I'm pretty sure the C258 uses the PC-410 and not the PC-415. If you're accidentally using the PC-415 (looks exactly the same) maybe that's throwing the rest of the paper detection system off?
                Just something else to check and try.
                • FuserNoob
                  Service Mgr, CISSP
                  • Jul 2022
                  • 139
                  I actually swapped out the printer on Friday - c258 with a c258, so the LC tray is the same unit that was working for them - loose power/data cable on the LC tray is the more likely culprit.
                  • FuserNoob
                    Service Mgr, CISSP
                    • Jul 2022
                    • 139
                    FYI - had the client reboot the machine and... whaddya know...works like a charm
