View Full Version : Biz 454e
copyman
12-13-2022, 12:51 AM
Hi
Is there a soft switch or something to reset toner gauge to full on this 454e B&W model? I put a new OEM toner in early and display still has a message "replace toner when indicated". I didn't have time to run halftones to run out toner until machine stopped and said to replace.
Firmware was just updated.
rrrohan
12-13-2022, 02:25 AM
dont think there is one for anything older than 8 series.
copyman
12-13-2022, 02:40 AM
Thanks, reason I asked is seem to recall a color 4 series bulletin about resetting toners all back to full? Think it might of been a firmware?
blackcat4866
12-13-2022, 03:47 AM
Just a longshot here ... is the front doorswitch being made? I had an 808 not too long ago showing "Add Toner". I changed the toner ... no change, but I did notice that the "Door Open" message did not appear when the door was open. The spring actuator for the front door switch was bent from slamming. =^..^=
copyman
12-13-2022, 05:40 AM
Thanks, I will check.
copier tech
12-13-2022, 07:59 AM
Hi
If you replaced the toners early then the gauge won't reset.
The only way to reset the counters is remove all toners then full full bleed gradations prints then fit each toner back when prompted.
tsbservice
12-13-2022, 08:35 AM
4/4e doesn't matter there is no switch.
copyman
12-13-2022, 06:59 PM
There is a F/W to reset toners. Thought I remembered seeing it. I had looked under regular FW but is was under special FW on Kon/Min dealer site.
Here are the Color & B&W F/W's to reset toners to 100%
Version GX7-K2
7/20/2015 347.26 MB C224e C284e_C364e_C454e_C554e_A5C10Y0-F000-GX7-K2.exe (https://cscsupportftp.mykonicaminolta.com/DownloadFile/Download.ashx?fileversionid=20971&productid=1608) Release Notes: bizhub C224e, C284e, C364e, C454e, C554e (LK-101) Special Firmware Version GX7-K2 Resets the value of Toner level to 100% when replacement of new toner cartridge
SEE DLBT1501508EN01.pdf
Version GX7-K2
7/20/2015 346.56 MB 224e 284e_364e_454e_554e_A61F0Y0-F000-GX7-K2.exe (https://cscsupportftp.mykonicaminolta.com/DownloadFile/Download.ashx?fileversionid=20976&productid=1666) Release Notes: bizhub 224e, 284e, 364e, 454e, 554e (LK-101) Special Firmware Version GX7-K2 Resets the value of Toner level to 100% when replacement of new tone cartridge
SEE DLBT1501509EN01.pdf
copier tech
12-13-2022, 09:08 PM
Version GX7-K2
Version GX7-K2
7/20/2015 346.56 MB 224e 284e_364e_454e_554e_A61F0Y0-F000-GX7-K2.exe (https://cscsupportftp.mykonicaminolta.com/DownloadFile/Download.ashx?fileversionid=20976&productid=1666) Release Notes: bizhub 224e, 284e, 364e, 454e, 554e (LK-101) Special Firmware Version GX7-K2 Resets the value of Toner lever to 100% when replacement of new tone cartridge
Thanks for sharing. :o
