View Full Version : Miscellaneous Image Controller Identification
masio
01-03-2023, 09:42 AM
I have bought Ex-Fiery for KM c6000, the seller said i had to install the software myself. he give me the package software ic-3600 v1.1.
i ve been tried many times install but nothing happen. it shows ERROR "DVD does not support platform!! Press OK to reboot" on monitor.
i am sure the DVD software is OK, but not sure for the EX-FIERY.
Can someone give me clue, how to identification of Fiery Image Control (IC) for Konica Minolta ?
thank you
emujo2
01-03-2023, 05:16 PM
IC 306--Fiery workstation--Software original is 80C-KM1.1 System iso
IC 413 Fiery hang on--IC 413 111 system.iso
Tags on the back should tell you what model it is, along with the windows product key. E
Synthohol
01-03-2023, 08:29 PM
if it has a dvd drive it has to be the tower fiery ic-306.
if you are getting the platform error then its likely the fiery had XP on it and the disk you have is windows 7 version but the fiery requires a RAM and BIOS upgrade to support to ver 1.1 to version 3.0 this is a paid upgrade.
you seem to be in the same boat i am, i need a copy of the original 1.0 software too. ver 1.0 is xp based so unless someone has a copy, KM (and the world) stopped supporting it a while ago. its not even offered on konicas site.
btw, if the model is "ex" whatever, thats a xerox fiery not a konica one im afraid. an IC-306 would have PRO80 or IC-306 on the front badge.
masio
01-04-2023, 04:40 AM
I have checked the label stick on fiery and there is no clue that mention the IC code. could you check picture attached please...
thank you for your help
56167
masio
01-04-2023, 04:59 AM
I guess you are 100% correct, it has XP on it, after i check the windows key label. and the other label says bizhub press c8000, but no IC-306 clue even on the front badge. Only KONICA MINOLTA.
So i assuming the package software is wrong, as you told that could be win7 version.
Thank you so much for your detail information
masio
01-04-2023, 06:22 AM
I am curious, i try to check the ISO and it shows XPPRO Image.
wich one is correct you think, ISO or FIERY ??
56168
Synthohol
01-04-2023, 01:22 PM
Pics are too small can't read.
The ic-306 is also known as the pro80.
I can't read yours. The big silver sticker.
https://www.copytechnet.com/forums/attachments/konica-minolta/56173d1672838860-image-controller-identification-20230104_081851-jpg
