View Full Version : Cf9001 set to haunt me
BUSHWACKER
02-03-2009, 01:00 PM
Greetings all,
Thanx for the last tip re error code the red wire was corroded, removed cut back and re soldered fan now a for away.
But the fuser roller section is not turning - if it is released and pulled forward all turns manually
Seems like a drive problem Any hints
Regards
Bush:mad:wacker
WaveyDavey
02-03-2009, 01:59 PM
the drive coupling can stick in, may just need a push from the rear and/or losen screws holding surround assy and it will locate
IIRC its been a while tho !
BUSHWACKER
02-03-2009, 05:24 PM
:)Thanx will give it a go
