View Full Version : HL-2030
pepito17
02-05-2009, 07:03 AM
All light diodes, try Reset does not, the drum and toner are new to 150 copies.
cosmin_mocanu
02-05-2009, 12:42 PM
try change the corona wire, of the image unit. And alsoo clen the corona asembly.
CopierTechofOmens
02-05-2009, 01:59 PM
Do you have an error message?
CopierTechofOmens
From the status monitor on the computer that is
pepito17
02-05-2009, 03:05 PM
printer only fan working, diodes flashing constantly, I can not print ...
CopierTechofOmens
02-05-2009, 03:15 PM
There is no status monitor installed for the printer on your computer? You probably have a fatal error code. Without an error code it is hard to diagnose. Most common fatality would probably be fuser related.
mitatech
02-06-2009, 09:47 AM
I have service manual. mail? I send.
pepito17
02-06-2009, 12:11 PM
I will very grateful, emai:pepito17@abv.bg
thanks!!!
pepito17
02-06-2009, 12:20 PM
e-mail: pepito17@abv.bg
mitatech
02-06-2009, 01:29 PM
Check mail.
pepito17
02-06-2009, 02:22 PM
Check mail.
Thank you very much, the problem is located ...."Fuser unit failure".
Thanks!!!
pepito17
02-06-2009, 02:53 PM
now looking part number of the fuser, if you know please write it..
vale24
02-06-2009, 04:49 PM
Could you send and at me:). My email is: vale24@dir.bg
mitatech
02-07-2009, 01:13 AM
Check mail.
E Winter
02-07-2009, 07:38 PM
Take care to order the correct fuser unit - afaik there are two different versions out there. If the thermistor connector on the main pcb is red you'll need to order the "S" version.
anyar007
02-16-2009, 03:23 PM
I want service manual pls send to anyar007@gmail.com.
E Winter
02-16-2009, 05:02 PM
I want more money at the ent of the month pls send to me@email.com.
Service Manual Requests - Copytechnet.com (http://www.copytechnet.com/forums/service-manual-requests/)
[/URL][URL]http://www.manuals4you.com (http://www.manuals4you.com/)
