40yearsplus
02-01-2023, 05:06 PM
Hello all,
Here is my info I have a KM 364e that will beep once on main power switch on then after a couple seconds cycle all copier Drive funtions with the first half tone screen in display. Then it dies driving and screen dies and beeps every 10 seconds or so. I have used the Manual and gone there. I disconnected the HDD to see if it would boot but no, I can feel it spinning. I put another Ram in no good.
I don't have a spare MFP PCB unit at the moment but I read on another forum where one man installed one but no luck either. I also read I could not put a used board in with the SDD thats in that unit also. Im in the process of getting a couple others for parts. I also know the process to order an sdd is complicated for a non dealer. Although if i get a used unit with its sdd in it then it sounds like I can put that in.
Here is a question someone may be able to help me with along with the above. the red D710 beside the chip does not light up and I saw on another unit the d708/d709/and d710 are lit when the machine comes to ready all red. I searched the manual as thorough as i could with search control F on. It will not find a D710 led indicator by the chip on the mfp board in the search and when i search the MFP i get over 1000 hits i tried to look though didn't see it if im blind let me know.
Let me know if you Konica Techs think In on the right track. Thanks All !!
