View Full Version : Bizhub C754e with Fiery black issue
Sandoval
02-05-2023, 02:17 PM
When printing black colors the image is not good. Developing unit is a new, fusing unit, transfer belt unit also, original toners.
Any suggestions?
56694
Synthohol
02-05-2023, 03:19 PM
run the halftone and gradation test patterns and determine if its an engine problem or physical issue.
what makes it classified as a Fiery issue?
what does the fiery demo page look like.
atdc levels? etc...
there are also a bunch of fiery color settings like black overprint composite black and the like.
have you changed the output settings on the fiery?
so many questions, can the copier produce a solid black halftone test pattern at 255?
just trying to see if its a fiery issue or a copier issue or even the paper for that matter.
tsbservice
02-05-2023, 03:53 PM
Any suggestions?
56694
Hello, black drum unit anyone?
Sandoval
02-05-2023, 04:34 PM
I tried halftone on 255. The problem is the same, so not the Fiery is the problem. Tried different drum units - same.
Sandoval
02-05-2023, 05:32 PM
image transfer roller?
I doubt, because its only on black.
L0rdC
02-08-2023, 05:34 PM
As in any machine, half tone 255 and interrupt printing to see if the drum generates well, as you said that it appears the same when testing another drum, I would bet on the developer unit, counter?
