View Full Version : MINOLTA DI 250
vaclav borc
02-05-2009, 06:04 PM
THE LINES AND TEXT WHICH ARE PRINTED, (ALONG THE MOVEMENT OF SCANER) ARE LIKE STAIRS. FEW CENTIMETERS ARE PRINTED STRIGHT AND WELL, THAN FOLLOWS STAIR,AGAIN WELL , STAIR ... THE END OF PAPER IS PRINTED OUT OF PAPER
EXAMPLE:
______________
_______________
___________________
I CHANGED COMPLETE SCANER BLOCK WITH ANOTHER MACHINE.THE PROBLEM
WAS GONE FOR ONE WEEK, THAN RETURNED.
I MEAN CHANGE THE cpu AND POWER SUPPLY? MAY BE ANYONE
HAD THE SAME PROBLEM.
wRONG MEMORY?
buster68
02-05-2009, 08:07 PM
sounds like the write unit is failing(laser).
vaclav borc
02-05-2009, 08:56 PM
when printing self test , it is perfect
minimerlin
02-05-2009, 09:50 PM
Check the fibre optic cable is not kinked, also ensure that the ends are clean.
Hansoon
02-07-2009, 08:24 AM
Had it several times, defective PWB-HGB board in the scanner unit located in the rear-right corner. Di-250 and Di-350 each have dedicated boards in case you want to swap.
Hans
vaclav borc
02-08-2009, 05:15 PM
Hans
I CHANGED SCANER UNIT BOTH HGB BOARD, PROBLEM WAS lessen.
after few days problem returned.
closer to optical cabel. scaned data are transfered by optical cabels?
Hansoon
02-08-2009, 05:39 PM
Yes the grey "tubing" coming from HGB board going to the main board.
http://img87.imageshack.us/img87/8214/fibercablelg6.jpg (http://imageshack.us)
Hans
kink#2
02-08-2009, 10:56 PM
Try removing rear cover for HGB board make sure nothing push on any of the HGB connectors, make a copy, if its good, re-route all the cable real good before you put the cover back on.
vaclav borc
02-11-2009, 03:43 PM
Today, I visited the customer and I replaced MFB board
(20 cm x 25 cm vith 2 bateries . Every cables not replaced.
When i made first copy , the problem was worst than that.Strong worst.
Once again:
first MFB board : the image is cuted litle
second MFB board: the same problem ,but the image is cuted very strong. is not
important notice : second board was not new, I took it of broken machine.
The same parts?Diferend problem? Looks like typical defect, typical illnes of this boards.
Is not there any calibration, when changing MFB?
As for optical cables, I tried to brake it , but reason was - that the machine halted and restarted to service mode.
mitchl
02-11-2009, 04:09 PM
Throw another known working HGB board in the pig, we have seen this problem unfortunately 100 or so times and its always the same deal, the HGB board. I think the same vendor made that POS board as the laser units on these models, hell we wont even cover the laser under contract so many went bad.:eek:
vaclav borc
02-11-2009, 09:08 PM
i dont understand clearly. Can you tell me again in easy english.
What shoul i replace? HGB board? I changed scaner unit , which includes
HGB board. Do you thing there is same problem with another board? So venture?
And how to explain, that I replaced MFB board and the intenzity of defect
was heavy increased.
thanks for any help
vaclav borc
02-11-2009, 09:16 PM
What should i replace? HGB board? I changed scaner unit , which includes
Is possible to repair HGB board?
thank for any help
