mascan42
02-18-2023, 01:18 PM
I have a machine with an FS-533 internal finisher that has managed to knock the stack actuator loose.
56935
Unfortunately, I can't work out how to get at this. I've managed to get as close as removing the bracket with the surface detection solenoid, but this actuator is much further inside, behind the alignment motors and gears (the motors are removable, in place, but not the gears and brackets). Has anyone ever had to remove the alignment plate entirely? I can only see the two screws on either side, but that doesn't free it up.
56935
