View Full Version : BH-363, main switch off and on
Hansoon
02-27-2023, 12:44 PM
I have many of these machines but never encountered this message:
"Switch main switch off and on" (or WTTE)
HDD, Memory, Boards?
Hans
Synthohol
02-27-2023, 01:37 PM
does not appear to be an error.
what happens after you do what it says?
Hansoon
02-27-2023, 03:09 PM
Remains the same, even when the mains plug was pulled longer than half a minute.
Will go there tomorrow with "frimwar", HDD, Memory, boards and some luck.......
Hans
emujo2
02-27-2023, 03:21 PM
Used to get that kind of cryptic message when Vcare stopped being able to reach the outside world, but this is a little different..I would search the manual and see if there are any codes that will flip the main power input to the machine..maybe a trouble reset and watching for fuser issues. E
Hansoon
02-27-2023, 03:44 PM
I did, but found no answer yet in the Tech Manual from 2014/01/27. Perhaps the search function of my PDF-XChange is weak?
Hans
emujo2
02-27-2023, 05:20 PM
You need to get into service mode before it throws that message..Starting the trouble reset sequence should allow you to get to service mode and look at the error codes being generated. E
tsbservice
02-27-2023, 05:29 PM
Exactly what I would do.
Can't remember but do these have some kind of self diagnostic like newer models?
femaster
02-27-2023, 05:42 PM
The 3-series machines like this do not. I believe that started in newer firmware versions in the 4e models.
tsbservice
02-27-2023, 06:28 PM
Hans, found this seems you may have bad HDD:
Bizhub 363 turn main switch off and on (https://www.copytechnet.com/forums/konica-minolta/117448-bizhub-363-turn-main-switch-off.html)
Hansoon
02-27-2023, 06:53 PM
Thank you so much. That confirmed my first idea and is exactly what I need.
Thanks to everybody here
Hans
Hansoon
03-01-2023, 11:53 AM
Problem solved. I exchanged the HDD and the machine is up again.
Thanks guys
Hans
blackcat4866
03-01-2023, 08:37 PM
Congratulations Hans. Thanks for posting back. =^..^=
