View Full Version : Miscellaneous Konica Minolta Bizhub C3350 - Gradation
mearmi
04-03-2023, 01:33 PM
Konica Minolta C3350 is not printing Right Colors.
Cyan and Magenta IUs and ITB are Newly Replaced.
Cleaned TDC Sensor and Laser Glass.
Did image stabilisation
Replaced the driver
Kindly also advise how to do the Color gradation in this model.
image is attached.
Many Thanks
copytechtrouble
04-03-2023, 01:53 PM
Replaced the driver
image is attached.
Many Thanks
something is wrong with the cyan unit. double check the connection and ensure the packaging tape is properly removed from the image unit and cyan toner cart.
there is also a procedure to follow when replacing the image units on that model, I've attached it just in case.
after that you can run the graduation in service - imaging adjustment process - stabilizer - initialize+image stabilization. once complete go to gradation adjustment and run through the graduation adjustments.
57614
tsbservice
04-03-2023, 02:02 PM
Yeah check cyan IU.
Btw this is non i-series model so attached bulletin isn't applicable.
blackcat4866
04-03-2023, 02:03 PM
Yup, cyan is missing. Try these originals:
tsbservice
04-03-2023, 05:30 PM
Make full cyan page and crash the machine mid copy to see which of belt or IU is bad.
