View Full Version : Bizhub 200 / NEC 2530 service mode.
eg101
02-09-2009, 09:33 PM
Have a NEC 2530D that needs developer. How do you get to service mode to do F-8. Meter and STOP,0,0 STOP,0,1 won't work. Otherwise the machine seems identical to a Biz. 200.
lvangsnes
02-09-2009, 10:07 PM
Touch Utility, Access, ****, at this poing the Start light will be blinking. Then touch Utility, Maintenance, then Service Mode. The Start light will continue to blink until the machine is powered off, then back on again.
lvangsnes
02-09-2009, 10:24 PM
Should have said "at this point". Also, I'm sure you know that you must replace the drum at the same time as the dev. (I was unable to edit the previous post as it just hourglassed).
eg101
02-10-2009, 02:53 AM
Yes the drum is new. I just needed to know how to do an F-8.
Many Thanks.
EG101
