View Full Version : print from fiery
gamalmehdar
02-10-2009, 04:30 PM
after installing the bizhub pro c6501 the ic 408 not printing and show me put color paper 81-105 gm in valied tray
i change the paper setting from control panel but same.
how can i correct this problem and prit from my pc throw the ic 408
thanks
brian155
02-10-2009, 06:01 PM
Job can be cancelled in printing/processing jobs.in ps setup you have to set wieght and type up to match what you have set in your trays. Also try switching start page off in general settings both done via web browser, you must enable this mode firstly on the engine controller set up(same place as putting in ip settings).
gamalmehdar
02-11-2009, 12:45 PM
when i send the print order from c6501 with ic 408 it show the error (there is no compatible finisher installed) the machine include RU-504 and FD-503 . and the copieng work ok
how can resolve this for printing from pc
thank again
kmcopier
02-11-2009, 02:25 PM
Set your papertray for color specific and it will print, our in the setup off the fiery the paper on normal.
buster68
02-11-2009, 10:16 PM
thank again
you don't have a compatible finisher arrangement for the IC-408.
gamalmehdar
02-15-2009, 06:30 AM
After i disconnect the finisher fd-503 the printer is working and the fd-503 not including in that options on the printer driver .
i do all that actions in installation manual for fd-503
ni311
02-15-2009, 09:18 AM
I believe is FS and not FD. Do you get any error codes? Try a firmware upgrade, I believe v40 it's the latest.
gamalmehdar
02-15-2009, 05:23 PM
that FD-503 multi fold and punch unit
its not coming in the options on printer driver .
kmcopier
02-15-2009, 05:37 PM
What is you system software version ???
gamalmehdar
02-16-2009, 08:20 AM
the versions
image controler 1 A03U0UO-0011-G00-41
image controler 2 A03U0UO-0012-G00-40
image controler 3 A03U04O-0013-G00-40
image controler 4 A03U0UO-0014-G00-10
image controler 5 A03U0UO-0015-G00-40
Printer controler C A0H00Y0-00C1-G00-40
Multi folder H AOHOOYO-OOH1-G00-10
random
02-16-2009, 08:58 AM
The IC-408 is ONLY compatable with FS-607,PF-601 and LU-202. I am surprised the RIP does not turn of automatically! How did you get this configuration?
kmcopier
02-16-2009, 08:25 PM
the system software is on the config page of the fiery
gamalmehdar
02-18-2009, 01:39 PM
then what can i do
did the firmware nedded to upgrading . but i think this the latest one
