C-350 not printing Copy Track Page I upgrade firmware and is still not printing when I hit print I hear a beep yet the machine say's it's printing on 11 by 17 normal but just sit's there doing nothing
Tags: acct, black toner, c350, copy, dead machine, hesitate, not printing, now printing, page, power outage, printing, track, waste toner
copy track page
JDD
Does it copy at all? Check that the copier has no IU's. toners or waste toner full messages. This may inhibit printing. Try powering it off and unplugging it for a 10 count, plug it in, main power, sub-power and try again. That being done, if it still does not print, flash it again.
Good luck! -
do you have the paper in the 1 first tray or manual bypass, and also in feeding direction. If soo.
We had one case where we had too install the dallas chip in a other C350 there could we print the counters.
After data clear on the original machine.(all settings and countes from accounting are gone then) made the setting again for the accounting.
The machine printed the counter list again.
KmcopierComment
Resonse to posts
I have tried the info posted-no error codes-although I have not tried reflashing Although turning it off and loosing everything sounds like it would work also not that I want to do it because of customr aggrivation but it sounds possible. I am working on a work around to see if I can view acct. using admin viewer on PC side thak's for your help and if you think of anything else let me know Thank You! JDComment
copy track page
JD
Hmmm, why does it want to print on 11 X 17? Mine have always defaulted to 8-1/2 X 11, and if that paper source is not available or empty, it beeps, says now printing and does nothing - like yours, It does not say paper is empty or give any error messages or info in the job status, just doesn't print.
Also, C250...after power outage and dead machine, had to re-flash firmware, but unable to run gradation adjust. Turns out, waste toner box was full when the power failed along with add black toner message. I had to bring the copier to a 'ready' state with a new waste box and black toner, and flash it again.
Good luck!Comment
Responce not printing
I do hear a beep that does not normally happen when trying to print counter report - the reason I use 11-17 is because that is what the display asked for when I put in 8/11 it would not turn the print button green you make very good points and thinking back I might of saw an oil can. Thank you for your help and will report back I am also a Kyocera dealer and if you need info on that don't hesitate to askLast edited by JDD; 02-16-2009, 02:53 AM.Comment
The C350 is a funny character when it comes to account track. On early firmware versions, if an account was deleted without first clearing that accounts data, the machine would lock up when you tried to print the account track info. The only way to resolve this was to clear all accounts data, turn off and the back on the account track. This glitch was supposedly fixed with the newer firmware versions.Comment
PC Side viewing Software Download
Until I get there printing copy track page problem fixed and going off the last post if I try that it will be at end of the month due to billing issues, as a work around I was wondering if thier is a download that I could use on PC side to view the acct info. and if so where can I get it Thank's JDDLast edited by JDD; 02-18-2009, 12:11 AM.Comment
The Copy Track account data will not print, even though the correct paper size is loaded. When this occurs the only way to clear the data print is to power OFF/ON.
Solution:
CAUSE: This is usually caused by the administrator deleting an account password, but failing to clear the account's data.
SOLUTION: To resolve this issue please clear all copy counts from any account without a password associated with it.Comment
Solution:
