bizhub 4050i - C6001 DF related configuration error 1
  • hobbele
    • Nov 2019
    • 38
    [Error Code] bizhub 4050i - C6001 DF related configuration error 1
    We just have a bizhub 4050i in the shop for repair and we are desperate...
    Have any of you had this error before and how did you fix it?
    We have already renewed all relevant parts, including the DF completely.
    We have reinitialized the machine several times, installed the latest firmware (G00-Q6), checked the machine type and the serial numbers...
    ADF is set to "Dual Scan Document Feeder"
    The error just won't go away..
    What are we missing?
    I found that too
    Detailed Code Differentiator = 0x1FFF - 108 Times
    Renewed Parts
    • DFCB
    • CPU Board
    • Base Board
    • DF Flat Cable
    • Connectors
    • the whole DF
    Error Code 6601, C6601, C-6601
  • Gift
    • Mar 2011
    • 2458
    Re: bizhub 4050i - C6001 DF related configuration error 1
    Are all of the replaced/new parts still in that machine or did you work step-by-step and swap it back everytime the error re-occured?
    I can imagine a faulty scanner assy might lead to this ussue as a side effect since it probably shares some data paths.
    • Mitch Barron
      • Mar 2013
      • 180
      I found that too
      Renewed Parts
      • DFCB
      • CPU Board
      • Base Board
      • DF Flat Cable
      • Connectors
      • the whole DF
      Have you replace the ADF? it may be the ADF the problem.
      • hobbele
        • Nov 2019
        • 38
        Everything was installed and dismantled step-by-step.
        Unfortunately, there is not much on the scanner. Just a motor and the CIS.
        The scanner does not move and we have now renewed the base board again. However, again without success.
        Thanks for you reply
        • hobbele
          • Nov 2019
          • 38
          Yes, the complete ADF was replaced, as I already mentioned in my initial post ;-)
          • tsbservice
            Field tech
            • 7970
            I had those 0x1FFF once and we ended up replacing CPUB.
            As you already said CPUB was replaced but was it with new or used?
            If used your need some extra steps to be done.
            • hobbele
              • Nov 2019
              • 38
              Its a new CPUB
              I'm wondering why the scanner isn't moving... I don't think it's necessarily the C60-01. This error is only thrown because the scanner is not moving...
              Motor, flat cable, CIS has already been renewed...
              We just reset the machine with the reset tool to rule out errors here too... unfortunately still the same error.
              • Gift
                • Mar 2011
                • 2458
                Its a new CPUB
                The scanner must show some movement if you turn the MFP on. You can also move the CIS out of the home position toward right and check
                if it moves back after turning the MFP on.
                If it doesn't move at all try another scanner unit or check the motor, flat cable, home position sensors...
                • hobbele
                  • Nov 2019
                  • 38
                  As I said, the Motor and the Flat Cable have already been replaced.
                  The sensor has been checked. Everything is good.
                  We are now getting the machine replaced by KonicaMinolta. There was a specialist there who hadn't found the error either...
                  • Gift
                    • Mar 2011
                    • 2458
                    Poor guy
                    • tsbservice
                      Field tech
                      • 7970
                      So sorry to hear you didn't make it work. It seems you did great job and replaced almost everything thinkable.
                      As far as troubleshooting my thoughts are good field service technicians are much more experienced than some KM reps. Most of the time I reluctantly throw parts into machine and only after anything else was explored and tried/tested.
                      • hobbele
                        • Nov 2019
                        • 38
                        I would have liked to have solved the problem... it would have helped our company and the community a bit. however, we have now wasted too much time and money
                        • rrrohan
                          • Sep 2011
                          • 1977
                          try system cache clear.
                          ive replaced CPUB in the past and error remained until i did this
                          • hobbele
                            • Nov 2019
                            • 38
                            We ran "Clean All Data" multiple times. We also ran the reset tool over it several times.
                            • rrrohan
                              • Sep 2011
                              • 1977
                              i dont know if all clear also does cache clear so could still help possibly
