View Full Version : Miscellaneous Konica C368,cant print from windows 11 S Mode
acsolutions
08-17-2023, 08:58 AM
Hello, Cant find driver for C368, printing from windows 11 S mode. Any suggestions? Thanks
B0265
08-17-2023, 11:56 AM
I don't think you are allowed to install any downloaded software i S mode. You need to use a built-in driver.
davidmtupper
08-17-2023, 02:41 PM
This is a correct statement, however the customer can switch from S mode to full Windows for free, just change the license (google for details).
Synthohol
12-14-2023, 11:06 AM
maybe best bet is save or print to pdf, put it on a flash drive and print direct from copier.
D Colour
12-15-2023, 03:55 PM
As other have mentioned Windows S mode only allows you to install apps from the MS store. There is one called "KONICA MINOLTA Print Experience" in the UK anyway.
"This is a print settings application exclusively for Konica Minolta's MFP/Printer.You can configure detailed print settings when printing from Windows Store apps using V4 Universal Print Driver."
Might be worth trying that, or converting to normal Windows.
https://www.microsoft.com/store/productId/9MVSXWCP9WH6?ocid=pdpshare
