View Full Version : Samsung scx-6345n error
TJRC
02-19-2009, 03:15 PM
I have a samsung scx-6345n with a system fault:0, file osal_psos.c, line 1435, task jmt51mt. If I get past the error not cleared just past then I get a no responce from mcb error.
blackcat4866
02-19-2009, 11:40 PM
I'm just shooting from the hip here:
As far as I can tell, the copier did not display this error on it's screen.
This looks like some sort of print error that popped up on the screen of your PC (possibly a Mac?). If this is correct, I would start with standard network troubleshooting methods. Check the driver configuration, and that you are using the most current driver for the right model.
The few times I've seen screen errors the IT staff got creative with the drivers (like using a HP LJ2200 driver to a Copystar color MFP: Why doesn't it print in color?). =^..^=
williamlozada93
04-24-2009, 04:13 PM
well... it's true... the copier displays this error on it's screen.
I have this truouble, in SCX6435N, but in service manual and service bulletins there isn't any reference about it.
Any ideas?
copytechman
04-24-2009, 04:19 PM
Sounds like a firmware issue, i'd reflash upto the latest version, don't forget about the patch (depends on where u start!) first so u don't toast the main board!
Regards!
A.
harigabi
08-11-2009, 08:12 AM
Hi!
We have the same problem with that Samsung MFP. We tried to upgrade the latest firmware but the problem still occurs sometimes.
