View Full Version : Running Envelopes for Konica C500
Can not find setting for C500 to run envelopes? Assuming it can be done on this machine with bypass tray? Just do not want to damage drum. Please respond ASAP.
Luther
02-26-2009, 05:35 PM
I dont see anything in the literature about envelopes thru any tray but i could be wrong
This is from KM solutions:
Envelopes are not included in the paper specifications. Konica Minolta does not recommend copying/printing onto envelopes.
The workaround is:
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
21043
03-05-2009, 02:03 PM
i print on C500 on envelopes DL size, short edge first - after 2500 envelopes there is a huge damaged lines on upper fuser roller, where the edge of envelope touches the roller.
after changing the roller, i print 200 and 500 DL envelopes, from bypass tray, paper normal 4, long edge first and envelopes was opened - opened clamp to rear, custom page size - 220x150 mm long edge first. quicker and no problems.
copier skills
03-09-2009, 09:04 PM
I had a customer that wanted to run envelopes on there c500 and they did until it jammed. I told them konica does not support it. In a nice way saying no envelopes are to be fed through th c500
