rossbiette
02-27-2009, 03:39 PM
I am having an issue with a customer on an Oce cm2522. I believe this is the same machine as Konica Minolta's c252. When the customer is trying to print a job (usually on a paper size larger than 8 1/2 x 11) the machine is returning a message on the op panel stating "There is no matching paper size. Load paper onto bypass tray. Paper: 8 1/2 x 14 Plain Paper".
Now a little backstory on how the machine is set up. There is 8 1/2 x 14 loaded into Tray 2 currently on the machine. The print driver is set to Auto Select the paper.
Is there anything that I am overlooking in the set up of the print driver so that the customer doesn't have to go to the machine to select the paper tray at that op panel? Any help would be greatly appreciated.
