DI470 scanner problem
  • darkmaster
    • 50
    Hi, i have impossible a problem. My machine can scan document but i can't see my file in computer. if i can print document using same PC. In my Job log record, the copier transmission successed for scan
    My copier IP address is:
    • IP address: 10.0.0.100
    • Subnet Mask: 255.0.0.0
    • Default Gateway: 10.0.0.2
    My PC IP adress is:
    My PC OS is windows XP. I close my Windows firewall already and i don't have any anti-virus software in PC.
    finally i using FTP utility for connect to copier.
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    If you're using FTP, you need to make sure the software path is set up correctly. Also make sure the rights on the file folder are set to allow other users to modify files in the folder.
    • wissows
      i cant see my scan file in my pc
      i configure the pagescope correctly and i fix the setting in my di470 and iam working as IT, i bought this machine as refurbished.
      my server ip is
      172.150.105.1
      dns: 255.255.255.0
      gateway: 172.150.105.1
      my user ip in my pc :
      172.150.105.44
      the minolta di470: 172.150.105.5
      dns and the gateway is the same
      i fix all the pc as printer and i try to scan
      a MESSAGE THAT THE SCAN IS TRANSMIT BUT NO FILE FOUND, CAN SOME ONE HAVE EXPERIENCE TO HELP HOW TO SLOVE MY PROBLEME,
      PLEASE NOTE: THAT I TRY TO WORK WITH FTP SERVER THE PATH IS OK BUT REALLY IAM TIRED 3 DAYS ONLY READ THE MANUAL AND COORPORATE WITH OTHER TEAM SAME PROBLEM ,
      WAITING YOUR REPLY ASAP.
      BEST REGARDS,
